Question about NetGear WGT624 Wireless Router
Reconnecting router unhooked the router to move now i cvant get it hooked back up not have directions and they tell me its out of warrenty now what can i do
  • 36 Answers
Connect your Internet provider to the WAN port
connect your COmputer to the LANPORT
Posted on Feb 02, 2009
Netflix was working fine now it is telling me that internet conection needed i checked conection and its fine
Wii has to reconnect in a specific state you will wont to unhook everything and then turn the router on and wait 5 min then plug the wii back in and let it find the connection.
Jan 13, 2011 | Nintendo Wii Console
Red light at power on
Too bad. The quickest/cheapest way to proceed is to buy another router, either online (through 'www.UsedEverywhere.com') or at a "big-box" consumer electronics store, for less than $50.
Aug 01, 2010 | Linksys Wireless-G WRT54GS Router...
I unhooked computer to paint walls. Now
I think you must be just unlucky.
I think the reset button just resets the wireless internet but I am not certain about that.
Usually when a router loses it's memory it needs a call to the internet service provider who will get inside it and reset the addresses and check the connections and so forth. This is usually necessary even if you own your own router rather than having one provided by the ISP.
Diagnostics says the router isn't connected to the internet so maybe that is the truth and the problem - coincidences do happen and maybe there is a fault somewhere on the line and it needs reporting to ISP so they can check it or get it checked.
It could be worth double-checking the connections and leads first. I recently had trouble with a phone that worked only when it felt like it. The trouble was a couple if pins in the master socket had gone green and was failing to make contact with the phone plug some of the time.
Apr 16, 2017 | Linksys Cable Modem
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Hooking up printer,scanner,copier,HPPSC1610V All IN one
Should plug into a USB port on the back or front of computer and to the back of printer unless this is a network printer you are talking about and in that case it should plug into the router or hub does not matter which port just look for an empty one and make sure the light on the router indicate you have plugged something in  Good Luck
May 04, 2009 | HP PSC 1610v All-in-One Printer
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Hooking up to docking station
No, the laptop will have to have a wireless adaptor on it or in it to connect. The docking station is only good when the computer is hooked into it.
Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
42 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
