Question about ATI ALL-IN-WONDER 9000 PRO (64 MB) Graphic Card
I'm trying to load my ATI catalyst software and it won't load
As I am going though the install wizard I get the "severe" message
"Setup will only run in administrator mode. Setup is aborting
In my Windows XP software I am listed as an administrator. Any other places to look, or suggestions.
  • jloyen Feb 01, 2009
    I only see a RUN, not Run As. Where are you suggesting I look for the Run As?
  • 565 Answers
Use run as and there choose admin
Posted on Feb 01, 2009
  • Teet Bergmann Feb 01, 2009
    on setup file use right mouse button and select run as
Changing screen size with ATI catalyst controller
Just had this problem last week.In your ati settings:My Digital Flat Panels > Scaling Options (Digital Flat-Panel) and turn the scaling down to 0%.
Dec 07, 2011 | Computers & Internet
Installed new video card, system reboots
your current graphics card settings is not set to the correct level to match your system, you can download ATI Catalyst software from this link:
http://support.amd.com/us/gpudownload/Pages/index.aspx
after installing, you may have to restart your computer. when you restart, right click on the desktop and select (ATI catalyst), there you can adjust your graphic card features or you can use the recommended settings the software have adjusted for your graphic card by clicking on restore settings/defaults.
you should not encounter problems once you have installed the ATI software.
Sep 09, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Configuring Laptop for Flat TV S-Video Connection.
Greetings,
Connect the second monitor to the blue VGA port. Download catalyst control center from the below link and install it. Using catalyst control center, you can configure dual monitor. You may need to check 'force tv detection' setting in catalyst control center.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-3_xp32_dd_ccc_wdm_enu.exe
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 07, 2009 | Computers & Internet
Iam from pakistan
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ATI that are available for your card.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
Jan 01, 2009 | ATI All-in-Wonder X800 XL, (256 MB) PCI...
NO TV on All in wonder 2006 agp
Recently had a similar problem and solved it today!
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (observing WDM drivers).
You should have downloaded the most recent catalyst drivers from ati, and the most recent multimedia center completely (about 80+Mb) that are available for your card.
Also visit the previous versions of the catalyst drivers, the all-in-wonder 2006 seems to be only compatible with the WDM drivers up to ver.8.4 and download it "alone" (don't worry if the latest drivers include the WDM, you can write v.8.4 over it any time).
ONCE YOU'VE DONE ALL THE INSTALLING OF THE LATEST CATALYST DRIVERS AND MULTIMEDIA CENTER (is a 4 part download, be sure to install the 4 parts "only the dvd codec is optional" and leave the MMC part to install at last) BE SURE TO INSTALL V.8.4 OF THE WDM DRIVERS (for the all-in-wonder 2006), OTHERWISE YOU'LL HAVE THE SAME BLACK SCREEN WHICH IS ALSO CALLED AN OVERLAY FAIL.
Restart and run your TV, it will work. Please check if your TV comes out at 240i resolution instead of 480i, you might need to disable the TV ON DEMAND feature of the tv program. This is done at the registry. Close the TV program and Run Regedit, then look at HKEY_CURRENT_USER\Software\ATI Technologies\Multimedia\Features\DTV\Channel Manager, the Key you need to change from 0 to 1 is the one called LiveMode. Close Regedit and restart. Start the TV program, and check, you should see the 480i resolution (at the top info bar), if not press ALT+3 and then ALT+2 and then ALT+1 (don't check any of the boxes in any of the questions), that should finally do it. Any problem? Just close TV program and do it all over again from the begining more carefully or trying some little variations in the ALT part.
All this solves many problems as with the TV program showing CORRUPT and BLACK or BLANK SCREENS with AUDIO which are also called OVERLAY FAILURES in many or maybe even all of the ALL IN WONDER (PCI Express or AGP) cards and even with the TV WONDER cards and USB adapters, the only difference between the cards might be the top WDM driver version you migh be able to use with an especific card. Please watch that you might need to try all the versions of the WDM available untill you find the one that works for you (the AIW2006 uses v.8.4, but for example the TV WONDER USB2.0 is able to use the latest available.)
Dec 04, 2008 | ATI ALL-IN-WONDER 2006 EDITION, (256 MB)...
When gaming everything freezes. my problem report states,
Try removing the Catalyst program that came with the video card, Re-install just the drivers but not catalyst. To do this, you have to go through ADVANCED setup when installing the software.
I have used nothing but ATI and the bigest problem i had as well as many of my friends, is that the catalyst program has major issues with certain computers, especialy custom built ones.
I burned up one and almost a second before i finely figured out it was catalyst.
WHen i spoke to ATI about the issue they offered no solution and denied everything but the evidence showed. Once i removed catalyst, it never had a problem since.
Try it out, couldnt hurt.
Let me know and good luck.
Dec 02, 2008 | Lenovo ATI RADEON HD 2400 XT - Graphics...
Radeon X800 XL AGP Card Installation Error
You should do a deep uninstall of all of the ati drivers present in your system... here are the instructions.
The "deep uninstall" starts by first uninstalling all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ati.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Jul 08, 2008 | ATI Sapphire RADEON X800XL RADEON X800 XL...
Driver
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (you will need to do this at native vga mode).
You should have downloaded the most recent catalyst drivers from ati or the manufacturer of your pc.
Apr 19, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Radeon ATI 9600XT video card
Try this, I just tested (2 days ago) an Albatron that arrived here with a 9800pro, crashing everytime they tried to play games.
I installed the latest drivers etc that "should" have resolved the issues...It made it worse. Updated everything including the chipset etc.
After driving myself crazy for several hours I installed the Catalyst 7.3 drivers... Away it went fine, tried the 7.4 (same problems as before), back to 7.3 and fine again.
So with Albatron boards and ATI cards, try the Catalyst 7.3 driver located <HERE>
Apr 16, 2008 | ATI RADEON 9550 Graphic Card
How to install ATI Radeon x1050 card to two screens on windows 2003
ATI can get confusing. You might have installed ATI's CCC, "Catalyst Control Center", along with the display drivers. I suggest you download the latest combo-CCC and drivers for your video card. ATI comes out with new drivers pretty fast. When using dual monitors CCC is where you want to setup your monitors. After you set up the catalyst control center you'll find it much easyer to assign what monitor displays what. One other suggestion. ATI will want you to uninstall any other software for your ATI card even though all you have is ATI software.
Driver site: http://ati.amd.com/support/driver.html
ATI's uninstaller utility: http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=1447
Nov 28, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
ATI ALL-IN-WONDER 9000 PRO (64 MB) Graphic Card Logo
161 people viewed this question
Top ATI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
