Question about Refrigerators
My refridgerator box fills with water
Whirlpool Gold Model#gt2shmxms03 Ice maker lines are tight, Clogged condensate line?
    President:
  • Refrigerators Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Feb 01, 2009
Whirlpool ice maker just making thin slabs of ice
What is the model number of your refrigerator this problem is usually caused by inefficient water supply to the ice maker on a whirlpool icemaker the fill valve seals for 7.5 seconds if the water flow is obstructed T-valve that are not recommended for refrigerator water supply lines the next problem could be your water control valve or the filters are clogged restricting water flow here's a short video
Appliance 911 Sea Breeze
Dec 04, 2015 | Whirlpool Refrigerators
Icemaker makes lil ice cubes now could this mean the line is clogged?
Would not expect you to ask this question but yes you are right cajunboudoin, an obstructed water line by either a defective water control valve, water filter beyond its useful life or a crimped water supply line will cause the ice cubes to be small during drop of ice cubes into ice bin. Fact is with Whirlpool the water valve is set to remain open filling ice maker for around 7 seconds. If water is moving slow filling the time will be to slow for the flow, If anyone has a good question you do but I would always want everyone to provide their model number, Click Here=> Whirlpool Ice Maker Troubleshooting Thanks Sea Breeze
May 06, 2012 | Maytag Refrigerators
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making any ice.
Hello there:
here is a couple of things to check ok
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 23, 2009 | Refrigerators
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
