Question about Honda 8 HP Engine
Drum on my concrete mixer is turning to fast
I recently took the diesel engine off my mixer and fitted a 8HP honda engine to it. Unfortunatly although the engine is in very good condition the gearing needs to be altered. What do i require and where can I get it from. Regards Bill Porter
  • Allen Neal
    Allen Neal May 11, 2010
    the ratio of the gear to rpm,s is sometimes tough to figure . what size are the pulleys or gears you have if chain drive try as best you can to determine the existing rpm you are turning now and tell me the rpm you think you would be more comfortable with and i will try to help and try to tell you where available
  • 211 Answers
Hi
At an engine lower and higher rpm is because of the governor sensitivity sistem.An arm attaches to the shaft(inside the crankcase)with a clamp-bolt/nut.This arm are provided with a series of holes.To decrease sensitivity hook the spring into a hole lower than its original position.If needed you can make some extra adjustment holes.Hope this help you.
best regards savumihai71
Posted on Feb 16, 2009
Air in crankcase
is the oil over full ??? then i would suspect a crankcase breather issue which should be in the valve cover... then I would be looking at a head gasket issue, rings or all of the above
Dec 28, 2013 | Honda 8 HP Engine
Concrete mixer motor pulley size
smallest available that fits the motor shaft ( around 11/2 ")
it is not the mixer speed you are worried about but the power required to drive a full mixer
Jan 25, 2018 | Dryers
My motorhomes Eberspacher combitronic heating no longer works on 240v although still heats water and heats on diesel.
Hi l had exactly the same problem with my combitronic, tried virtually everything, asked & took my motorhome to several places found one that could find the fault. Apparently there was a break down of a wire under the sheathing stopping the heating working on 240v. Agency supplied if required.
Jul 23, 2012 | Dryers
HELO I recently purchase a 460V H600T hobart mixer 2.5 AMP/ 3 PHASE but unfortunatly our bakery only provides 110V or 220V what are my option??
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Sep 05, 2011 | Hobart H600 Stand Mixer
I have a honda 8hp on a mortar mixer. it gets fule in the bowl but will not run long. lite iys just using the fuel in the bowl. It used to run great. It has sat for a year.
first thing to do is take the fuel bowl off.then turn the fuel tap on.fuel should be running out of the needle from the carby.if not, the needle and float is not working properly. turn the fuel tap off .spray some carby cleaner into the needle and seat. turn the fuel tap back on and lift the float up,this should stop the fuel from coming out.and when you let go of the float,fuel should start coming out.
lift the float up and down a couple of times to ensure it is working. put fuel bowl on and run.
Dec 28, 2010 | Honda 8 HP Engine
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Zanussi ZWF14070 - concrete 'damper'
Moulded plastic 'spigots' still form part of the drum housing, but no concrete block is now fitted to the rear.
Nov 16, 2009 | Zanussi ZWF14070 Front Load Washer
Timing this engine a1974 tecumseh 8hp
if this is a single cyl engine ,the timing is correct when the match marks on the cam gear and thecrank gear are lined up .
Sep 16, 2009 | Honda Jenny GT8HGB-8P2 8hp 8 Gallon GX...
Mixer keeps cutting out! Please help!
As far as I know this is a food mixer. Concrete will definitely cause the overload to trip. Frequent triping has caused the overload to weaken and hence trip at lower values. You probably need to replace the overl;oad
Sep 22, 2007 | Hobart A200 Stand Mixer
Honda 8 HP Engine Logo
127 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
