Question about Indesit W 123 Front Load Washer
Whirlpool will not spin out water
Whirlpool washer will not spin out water.
  • 1,122 Answers
Clogged water pump or bad door switch-let me know-mike
Posted on Feb 03, 2009
Trying to locate the belt on a Whirlpool washer
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
With it spinining fully it may be as simple as a sock or undergarment in the pump, if it is not spining fully the motor coupler is probably in need of replacement
Feb 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil, transmission oil. if present youll need a new transmission and clutch assy
Mar 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
