Question about Your One Source Square D #HOM 115CP 15A SP Circuit Breaker
How to fix a circuit breaker after a fuse blows
I have Multi9 breakers, i was cooking and all the power went, i tried to flip the switch again and there was a little spark and it won't go back on, how do i fix this???
    Sergeant:
  • 359 Answers
The first thing i would do is to remove the feed wire from the breaker and see if will reset if it does you have a short in the system , tell me more about the system and maybe i can advise further
Posted on Feb 01, 2009
Machine keeps blowing power circuit
I'm going to assume that your talking about the switch in your breaker/fuse box and not the power switch on the machine it self. Check the line that your machine is on to make sure there isn't too many things plugged up and being used at the same time on that same line causing it to overload the breaker. Many times, it is other things that are also on that line in your kitchen like the microwave, toaster, etc. that causes it to flip the breaker switch. If you are using two or more things at the same time on the same line with high amps on each unit, it will sometimes cause the breaker to flip off. Try limiting using just one thing at a time to see if that solves your problem. If it is the power switch it self on your machine, then there may be something wrong with your unit and may be defective.
Jul 11, 2015 | Coffee Makers & Espresso Machines
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Electrical problem,nno power to two 3 way switches and one outlet
First are they normal breakers or are they GFI breakers? If they are normal then odds are one you have a short on the output of the breaker or perhaps the wires on the output of the breaker are loose. You also might want to check the boxes behind all of the effected items (switches and outlet). There could be a loose connection behind them. If they are GFI breakers then you either have a bad breaker or a bad ground on the output of the breaker. GFI's sense bad grounds this is what protects you. I'm not sure if the idiot light breakers light only if there is power available to them or if they only light if there is power flowing through them. If it is the fore then I say you have a high power draw on the output, most likely a short if it is blowing the breaker. If the breaker is not blowing then you have a loose connection or bad connection. Get this fix quickly either way because it can cause a fire.
Jan 05, 2014 | Wiley Print On Demand Electric Circuit...
99 Carolla pwr windows not working.
You'll have to get someone to trace the circuits to find the short. You can unplug the master switch in the driver's door and use a circuit breaker in place of the fuse or a fresh fuse.
Toyota door switches have a history of problems. If you disconnect the master switch and the new fuse or circuit breaker does not blow, I would try another switch. You may also have a problem with the wiring harness between the door and the post.
If the new fuse or breaker blows, you will need to disconnect the other motors and switches or look for a short in those circuits.
Jun 22, 2012 | 1999 Toyota Corolla
Power went out. Is there a way to reset it?
If all the power went out in your whole house, then you need to flip the main breaker switch off then back on again. This should restore power.
If only frig went out, then which secondary breaker switch is "triggered" and flip off then back on.
Dec 31, 2011 | Refrigerators
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
I am looking for a merlin gerin circuit breaker but i cant find out where i can buy it from.
Her ya go:
http://www.drillspot.com/products/160507/Merlin_Gerin_MG24434_Miniature_Multi9_Circuit_Breaker
Feb 19, 2009 | Merlin Gerin MG24434 Miniature Multi9...
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Your One Source Square D #HOM 115CP 15A SP Circuit Breaker Logo
710 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
