Question about Hotpoint Dryers
Water not heating or drying
I have an Hotpoint WDL 520 washer dryer. The other day the fuse blew in the plug whilst in washing cycle,ever since the water is cold and it will not dry. It is less than 6 months old surely the element hasn't gone already?
  • Hotpoint Master
  • 3,463 Answers
It is possible that the element has gone, \even after such a short period of time.
If it is only 6 months old, then you need to contact Hotpoint service department, and get it fixed under the guarantee, do not try to fix it yourself,, as you could invalidate the guarantee.
If you look inside your user instruction hand book you will find the telephone number you need to ring to get service.
Please rate my fixya solution.
Thankyou.
Posted on Feb 01, 2009
The tumble dryer on my hotpoint WDL 540 is not getting warm. I assume it's the heating element, but would be grateful for advice if it could be anything else or how easy it is to fit a new...
hello i'd check the heat sensors first there may be 2 of them you will need a multimeter to test them if 1 is faulty change both of them hope it helps
regards
shaun
Mar 11, 2011 | Hotpoint Aquarius WD640 Front Load...
The dryer on my hotpoint wdl 520 works but does not get hot!, any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Hotpoint Dryers
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Door won't open for Washer Dryer
WHAT HAS HAPPENED HERE IS THAT IS THE INTERLOCK HAS SHORTED AND BLEW THE FUSE AND THE REASON WHY THE MACHINE WORKED CAME BACK ON IS BECAUSE THE INTERLOCK HAS NOW OPENCIRCUIT AND THAT IS WHY THE DOOR WILL NOT OPEN JUST REPLACE THE INTERLOCK
Apr 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
