Question about GE Spacemaker JVM1640SJ Microwave Oven
Light replacement je1460bf microwave interior light replacement......can't get to it......help
  • 257 Answers
Hi, Remove the 2 screws in the grille, the grille pulls straight out (with the door open is a little easier). Then above the light is a cover plate which is removed by the two screws on the plastic frame. You will see a little tab that allows you to lift that cover plate out gaining access to that bulb. As always you should be safe and turn off the power before you repair any electrical device. Good Luck!
Posted on Feb 01, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
Ge microwave interior light bulb replacement. model #PVM1970SR1SS
Open the cover n you will see the bulb open it by turning it sideways
Sep 12, 2014 | GE Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How to replace interior light
I would imagine that like most you will have to take of the outter shell of the unit and it will be accessible from there. Should be about 8 screws.
Jan 22, 2013 | Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
125 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
