Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
FUSE KEEPS BLOWING WHEN POWERING ON
Philips 42pf9966 42 in hdtv ready plasma fuse keeps blowing when powering on what do you think, PS I can here a click each time I try.
I can use a soldering iron do you reckon I can fix it myself.
  • 1 more comment
  • pop_rivett Feb 01, 2009
    I have identified the big storage capacitors but I am not sure about the rectifier diodes supplying the big storage capacitor(s) can you give me more of a clue what i am looking for & what test results I should get from them using a multimeter. Also can I damage any of the components using a multimeter, Regards pop
  • Martin B
    Martin B May 11, 2010
    There are usually 4 together, black & cylindrical with a band round one end. Where the mains comes onto the board. If there is a shorted one then the resistance will be signigicantly different from the others, probably only a few ohms.
    Sometimes they are moudled into a 4 leg block I dont know about this particular TV
  • Martin B
    Check the rectifier diodes supplying the big storage capacitor(s) with a multimeter. One of them might have gone short circuit.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Magnavox 37MF437B/37 keeps blowing fuses
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Dec 08, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fuse keeps blowing!
The fuel injection fuse should also power the injectors. If the fuse is blowing, I would think one of the injectors has shorted to ground.
Have you checked them ?
Jul 20, 2012 | 2001 Suzuki Grand Vitara
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
F9A03 fuse on main power board keeps blowing. tried replaceing it and blew again
This indicates an electrical short causing the fuse to "safety". Check your house wiring first e.g. the plug and then precede from there.
Mar 05, 2011 | Mitsubishi WS-48313 48" Rear Projection...
My 2002 Sebring keeps blowing the starter fuse?
Mine is doing the same thing. We are getting ready to replace the starter. Hopefully that is the problem. I'll let you know how it turns out.
Feb 28, 2010 | 2002 Chrysler Sebring
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Jun 01, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Keeps blowing fuses
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Philips 42PF9966 42 in. HD-Ready Plasma Television Logo
592 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
