Question about Netopia Cayman 3347W-Ent Wireless Router
Bought used modem and don t have user name and passord
I bought a used Netopia Cayman 3347w cheap but can't get the existing username and password. How do I reset these security settings. I have tried the usual admin and password defaults with no luck.
    Problem Solver:
  • 13 Answers
On the back panel you will find reset button. press and hold for 20sec. So your router will get back defaul settings.
Posted on Feb 11, 2009
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
Set up router
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 18, 2011 | Netopia Cayman 3347W-Ent Wireless Router
What is the user name ?
I searched the user manual, and it does not specify. Try leavng it blank or try Admin.
If it was bought used, it may have old old info in it preventing your access.
Use the recessed reset button next to the power input to restore to factory settings. Hold for about 10 seconds then power off then on.
Dec 03, 2010 | Netopia Cayman 3347W-Ent Wireless Router
The red light under "internet" is on instead of green. We show connected on our pc, but when we try to connect to the internet we cannot get a connection?
Turn the router off, unplug it completely for 10 - 15 mins, then replug and turn on. If the problem is still present, press the reset button (small small hole, may require a needle) for 5 - 10 seconds if needed then follow the first step.
Mar 31, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Unable to go online with WPA-PSK enabled
What is the operating system on the computrer ?
If it is Windows XP Sp1 then it will not support the WPA.
You can change the security to WEP.
Or you can update the Operating system to XP- SP2
Make sure that you are using the correct password while connecting to the network
Click Here to know more about routers
Nov 20, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Tried to update firmware nir82R1. Got update
That wont help either!!!!!!
What you can try is .....try once more to update firmware in case you still get that same message.Please get in touch with technical support of Netopia ask them to update your firmware
Hope this will resolve your issue
Nov 02, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia 3347 moved to a different location/tel number
If you got the netopia in anyone of the 13 states that ATT controls, then that netopia will work in any other state, not just the phone number it was attached to. We are implementing technology now that it will be phone specific, but most people dont have that installed yet.
All you have to do is reset the netopia, open a browser, type 192.168.1.254 and set it up with the new username and password you created when you got your new DSL service.
spin
Feb 18, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Could you walk me thru connecting a Netopia 3347WG router
in the ATT region, they use PPPoE (in general, even if you have sticky static IPs)
plug in the router, turn it on, open Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
click on configure, then click on quickstart
type in your username (the emaill address from ATT like lc61544@att.net) and your password for your email address
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, you can open IE or firefox, whatever
and see if you're online (you should be)
spin
Jan 17, 2009 | Netopia Cayman 3347W-Ent Wireless Router
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia Cayman 3347W-Ent Wireless Router Logo
330 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
