Question about Indesit W 123 Front Load Washer
Need to replace carbon brushes on Indesit Omega 1200
Machine will only spin when empty. Suggested brushes need replacing. Where are they located and what is involved in replacing.
  • lgillett Feb 01, 2009
    Many thanks
  • Indesit Master
  • 3,463 Answers
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Dec 31, 2010 | Televison & Video
Indesit omega 1100 won't spin or rotate with clothes in
Sounds like the brushes in the motor need replacing, remove the motor, and check brushes, if they are less than 2-3 millimeters long, then they need replacing, not too expensive.
Please rate my solution.
Thanks.
Oct 28, 2009 | Washing Machines
Washing machine wont spin
It is unlikely to be the motor faulty, if it will wash but not spin, check the pump filter first to be on the safe side, if that does not solve the prob, then remove motor and check carbon brushes in motor, as this can often be the cause of the prob.
Also check the water level switch pressure chamber for a possible partial blockage, as this can give the same sympyoms.
Plz rate my solution.
Thanks
Jan 02, 2009 | Washing Machines
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Continually spinning
indesits dont have carbon brushes they have a module which controls everything to your tomer if this is faulty or your timer then its not worth doing too much in money to replace get a hoover or candy same machine just ones the uk model and the other is the us model dont go for hotpoint though because indesit own hotpoint now and there changing the carbon brushes to modules which is a big mistake alot dearer to replace then the carbon brushes but maybe thats why there doing so customers have to buy another washer check the price by going to indesit customer support web site but i always keep customers away from indesit due to that module some hotpoints are still the carbons but some arent cheaper to buy a slight damaged from a washer repay shop they usually have damaged at a fraction of the price save at least £125 per washer or buy a repossed one may off been used at the most 10 times nothing wrong with them and you will save £200 plus m8
Aug 23, 2007 | Indesit WA 115 Front Load Washer
W123 Wont rotate
some indesit washer have a module if you pull your washer out make sure power is off take the back off and you will see it on your left hand side it should be in a plastic cover with about 8 wires going into the cover there should be 2 screws that locate this to the back of your washer if not then it will have carbon brushes if these are lower thanabout 8ml long they need replacing these are locatable in the motor by having 1 small wire going onto them they will be plastic with the carbon inside pf them m8
Aug 12, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
395 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
