Question about Akai LCT2715 27 in. LCD Television
There is a loud hum on my 32" AKAI LCD TV on all channels.
This hum can only be shut off by muting the set.
  • 2,322 Answers
The humming noise is cause by defective capacitors in the power supply 12 volts line. These capacitors become defective due to the amount of heat surrounding them.
I repair these power supplies. If you need further assistance, write to jah2mil@hotmail.com
Posted on Feb 07, 2009
My akai lct3201ad tv volume just stays at 100 cant turn down or mute or source to change tv to channel 3 what can i do to fix this problem?
replace the main board. You can get the replacement main board from www.tvcircuitboards most likley if they dont have it listed I would send a email as they only list boards that they have more than one of single boards are not always listed.
Jan 02, 2013 | Akai LCT3201AD 32 in. LCD Television
Olevia 32" lcd tv made a loud, popping noise, shut off & now it won't come back on. When it popped, I noticed a spark
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Feb 03, 2010 | Olevia LT32HVM 32 in. LCD Television
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai 55
I used" Silerado 1st" solution. I have an Akai pt5598hdix/sms.
I had ghosting.Like 3 colors side by side.
Silerado said with TV off press "mute,1,8,2" then TV on.
I didn't see anything like a menu.He warned to write down any setting you saw before you change anything.But for me nothing came up. So as he said the next step try with TV "on" press "Mute,1,8,3" this is another set of adjustments for finer detail. I lined/overlapped all the lines up or down or side to side useing the channel and the volume buttons and then held the enter button down until the TV flashed 3 times.Then I shut it off and when I turned it back on It was perfect.
Thomas Fitzgibbon
Mar 23, 2008 | Akai PT5598HD 55" Rear Projection...
LCT3201AD tv mode stereo only?
AKAI told me that I needed to get a cable tuning box to fix this.
No other way would work
Nov 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai hdtv 1080i, No Sound
I sounds like a bad filter in the sudio supply circuit finally took out the sound output chip or the power supply that controls the sound circuit. its a soliud state set and there are no user replaceable parts inside this set. Unless you have had solid state repair experience, please be safe and call in a pro to assost you in this repair. good Luck ps Please rate this thread
Oct 19, 2006 | Akai PTH5498 54" Rear Projection...
Akai LCT2715 27 in. LCD Television Logo
105 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
