Back to:
Tags:
Nikon CoolScan V ED Film Scanner
Nikon 4000ed channel problem
By Mini Me - usenet poster
I have a Nikon 4000ED, using Nikon Scan 4.0.2. When I turn on the the
scanner and preview, I will have one channel act as if the gain is set
at ~ -3 (min gain is -2). So the image will either be lacking blue or
green or red. I can usually get the channel back by turning off the
software/scanner and turning back on again. But that is working less
and less. I have uninstalled and reinstalled the software, but no go.
ANyone have this happen to them before?
Thanks,
john
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Peter1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks Fred,
That does not seem to be my problem though as I tried to scan older
slides that I never had a problem with before and I had the same
problem. So I guess I will have to contact Nikon...
John
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on nikon 4000ed channel problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Grant
Rating: 0%, 0 votes
John,
I have had a *somewhat* similar experience. By any chance are you scanning
unusual sized slides?
I have a Coolscan V ED and use the Nikon Scan 4.0.2 also. I recently
scanned a couple thousand slides for the family.
A few of these were not standard 35 mm film in slide mounts, but rather
about 0.9 inches square. They were mounted in 2x2 inch mounts, so they fit
into the scanner OK. The cutout for the film was about 0.9x0.9 also. What
happened to me was that one of the color channels would cutout - some of the
time. It might happened during the Preview or Scan or both.
I contacted tech support, who was extremely helpful, and basically they
agreed that it was a result of the undersized slide. They suggested that in
my case better results could be had by not inserting the slide fully. It
did help. That is not to say that it worked 100% of the time, but it did
get me through the job eventually. Another "fix" was rotating the slide.
It seems to help. Apparently, they use information from near the entrance
edge to make at least one of their global adjustments and if this isn't
possible because of the slide mount totally blocking the sensors, then their
S/W will go bezerk some of the time.
Hope this is your situation and that this helps.
Cheers,
Fred
Thank You!
Can you Help with these Scanners problems?
Nikon CoolScan V ED Film Scanner (35 mm)
base station says HANDSET OUT OF RANGE
My coolScan V was working fine and then started putting...
"Software could not be launched. The device is not...
Hi, Could you please confirm if I can plug my Coolscan V...
Hi 1. when I first started using the Nikon CoolScan V the...
Loading problems.
Repair Service
Find Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
