SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document.
Method one: Scanning with Windows Photo Gallery
Method two: Scanning with Windows Fax and Scanning
NOTE:
This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
Method three: Scanning with Paint
SOURCE: Dell 964 scanner
First do your scan on Dell 964 scanner &printer. Scan to clipborad. You hear it scan but nothing happens on your computer. Go to control panel - scanners and cameras - scan profiles - find the document you have scanned, select it and click edit - click preview - in the left corner you will see in blue "How to scan a picture" click that, it will lead you to Windows Photo Gallery - there click on file and import from scanner of camera - it will scan there and your scanned pics will be in your picture folder :) Took me a while to figure it out :)
You can avoid all this and go directly to Windows Photo Gallery :)
