Question about Microsoft Xbox 360 Console
Xbox wont find ip address
My xbox finds a wired connection but when it tests for an ip address it says failed what is the problem? i use the same cable to go on internet on my lap top so i have to chop and change as and when i play on my xbox 360
  • Dale Van Camp
    Dale Van Camp May 11, 2010
    Do you have a cable/DSL modem that has multiple network jacks on the back (switch or hub)? Make sure your modem/router has DHCP turned on and configured correctly. Usually the factory defaults for DHCP work good on most routers.
    Problem Solver:
  • 9 Answers
It may be that the modem/router has to be reset everytime you change devices.
This is because the modem only recognises the devices that are first attatched to it. It will connect t the modem, but it will not get internet until you reset it.
I have the same problem with mine, can be a nuisance but it's the only way it will work.
Hope this helps,
Ed
Ps, you should have got a PS3.... =)
Posted on Feb 01, 2009
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Ip address fails test connection
you need to set your 360's network to automatically detect your settings if you have other devices hooked up to the airport and they work it is not the Airport.
When it says IP address failed it has nothing to do with comcast it is your LAN having issues not your WAN
Mar 30, 2009 | Microsoft Xbox 360 Wireless Controller
It wont go on live it keeps sayin fail when i try to connect
What does it say? For example ( IP Address failed?, DNS failed? Xbox Live Failed )
test your xbox live connection to do this
Mar 27, 2009 | Microsoft Xbox 360 Console
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Mar 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
My adapter is Wired but my IP address Fails :(
I am not sure how to fix it through multi-wired interned but the best way to get connected to the Xbox Live is to give it a direct access to the internet.
Try to look into your manual you got with your Xbox and find how to connect it through other means than direct access.
In the meantime, before you find a way - your best bet is to just take your internet cable that is connected directly to the modem and connect it to the Xbox.
Dec 31, 2008 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 live
find the IP adress on ur router if its wirless
May 16, 2008 | Microsoft Xbox 360 Console
IP address
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Apr 13, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
