Question about Microwave Ovens
I have a GE JVM1650 with an apparent magnetron issue. It was manufactured it 2005 so it's probably not under warranty at this point. I think I will just go out and buy another microwave. Wondering what brand(s) are best, and will any 30 inch unit work? Will vents line up the same?
  • William Miller
    William Miller May 11, 2010
    They should have a 9-year warranty on the magnetron, but you would have to pay for labor.
    What are your symptoms?
  • Microwave Ovens Master
  • 9,047 Answers
GE Customer Service is
here and they can tell you what model would be a "drop-in"replacement.
Posted on Feb 08, 2009
The controls along with the clock and timer works on the mircowave. The problem is that the food does not cook or heat up.
probably a defective magnetron; very common for this vintage microwave. there are usually generic magnetrons available; as the original GE part will be expensive.
Aug 25, 2010 | GE JVM1650 1000 Watts Microwave Oven
Smelled like something was burning and stopped heating. Turntable and lights work
I have GE microwave with a failed Magnetron. It is emitting large sparks. Upon removing the magnetron I found that the sparks left residue where they are leaking from the cylindrical shaped piece on the end of the Magnetron.
The Magnetron is under warranty.
BUT
GE WILL NOT HONOR THEIR WARRANTY AND SEND A MAGNETRON.
GE HAS SENT OUT HUNDREDS OF MAGNETRONS TO CUSTOMERS - SEARCH ONLINE TO SEE THIS IS TRUE.
I called GE PARTS, GE support and GE consumer relations department. They changed their policy two weeks ago and require a service technician to replace the part.
THE COST IS $220 FOR THE REPAIR TECHNICIAN.
Since I already removed the part the service technician would have to put in 3 screws and plug in the cable...FOR $220...I PAID $229 FOR THE MICROWAVE NEW!!!!
DO NOT BUY GE.
DO NOT BUY GENERAL ELECTRIC.
GE DOES NOT SUPPORT IT'S WARRANTIES UNLESS YOU ARE WILLING TO PAY THE SAME AMOUNT THAT YOU PAID FOR THE PRODUCT!!
Further research:
GE Microwaves can spontaneously turn on and start a fire - see Consumer Reports web page here:
http://www.consumerreports.org/content/cro/en/consumer-reports-magazine-march-2012/kitchen-fire-safety.html
Further evidence GE retroactively changing their warranties:
http://www.complaintsboard.com/complaints/ge-california-c197693.html
Nov 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
Need part # for GE ZE1660SAoo3 magnetron
HTML clipboardYou can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
But if it's under magnetron warranty, G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
Nov 28, 2009 | GE Microwave Ovens
Microwave not working after it ran without food in it.
try unplugging the microwave for a while then plug it back in.
Aug 29, 2009 | GE JE1860 Microwave Oven
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
They may send you a replacement magnetron. GE Customer Service is here.
Nov 25, 2008 | Microwave Ovens
Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Jan 27, 2008 | GE JVM1650 1000 Watts Microwave Oven
SpacemakerXl Microwave Oven JVM1650/1651
The magnetron may be failing or overheating.
There is a known issue with many GE models.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650
The owner's manual will give you the warranty length. If you don't have yours, you can find it here: http://www.geappliances.com/shop/prts/
You really need to call GE on this. Only they can answer if they will still cover it. GE Answer Center -800-626-2005, 24 hours a day, 365 days a year.
Otherwise, it may fall under your State's lemon laws. You can contact the Attorney General's office, usually via http://www.state.xx.us (where xx is your State's 2-letter abbreviation).
Nov 04, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
