Question about Crosley CDE6000 Electric Dryer
I have a crosley dryer that tumbles but doesnt get warm at all
Why did my 2 yr old crosley dryer stop getting still tumbles but no heat. it is all electric
  • 640 Answers
Check thermal fuse...onthejob
Posted on Feb 03, 2009
Crosley dryer not getting hot
Most likely a heating element or blower assembly concern. The only true way to know is to have a full diagnosis completed on the unit.
Aug 03, 2012 | Crosley Dryers
Dryer keeps going out - 3rd time since January. It tumbles but no heat. I've replaced the thermal cut off #279816 and the element #279838. I cleared out the vent all the way to the roof. I've...
Hello this will be a bit of an odd question at first but have you ever dlinted your dryer? Just as your dryer vent does get a build up of lint the dryer does as well. Click this link to view a tip I wrote the most important area to clean is where the blower goes into and you get at this area by removeing the rear panel of the dryer if your dryer is a type like whirlpool, kenmore, maytag all dryer need to be dlinted at least once per year to maintain the dryers ability to dry. If I am able to bring a 45 year old dryer back to life by doing this you should have no problem If you have any questions message me back this will require also the tub being removed as well but I can guarantee if the air is unrestricted the heat is able to travel unblocked and it doesnt cause blown thermistors as well . Thanks Rick
Aug 10, 2011 | Dryers
My dryer quit heating and doesn't quit. It keeps tumbling non stop but with no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Apr 20, 2011 | Crosley CDE6000 Electric Dryer
My 6 yr old Kenmore Elite dryer no longer heats up to dry clothes. It passes all diagnostics & thermister, moisture sensitivity circuit + all relays test ok. What would I look at next and if it's the...
I had a similar problem if it is a 220V dryer you may have tpipped a circuit or blown a fuse. The unit will tumble and circulate air still but the heatin element is controlled by the other circuit. Hope this helps..let me know Thanks!
Feb 16, 2011 | Kenmore Dryers
2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Apr 07, 2010 | Samsung DV218AG Gas Dryer
Dryer turns on but doesnt tumble
all dryers are belt driven.
defiantly a belt issue.
just to help with installation belt loops UNDER idler pulley to the motor pulley
hope this helps
May 26, 2009 | Crosley Dryers
Dryer runs and tumbles clothes but there is no heat therefore does not dry the clothes
the first thing to check is heating element if it checks good then it will be the thermostat
May 09, 2009 | Crosley CDE6000 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
Dec 21, 2007 | Malber TD700 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
356 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
