Question about Honda 8 HP Engine
Honda GX 160 5.5 Jet wash shuts down when use water
It starts but when i use the jet wash it shuts down with some wierd noise
  • Les Smith
    Les Smith May 11, 2010
    Do you have the throttle open far enough?
2 Suggested Answers
  • 211 Answers
SOURCE: Hello. i have a honda
Hi
Change the spark plug with a new one with the same heat range.
best regards savumihai71
Posted on Feb 13, 2009
My Honda gx 390engin will start but sputters as if missing while in idle and at higher rpms whats wrong
inside the carburetor you have to clean the main jet and nozzle first shut fuel off,remove the bottom bolt of fuel bowl and pull away,inside the stem where bolt came out of are the jet and nozzle using a #2 screwdriver insert in the stem and carefully remove jet without stripping it the nozzle is behind the jet you would need a small tool like a bolt extractor or easy out to pull the nozzle down it may be stuck from the varnished fuel.i usually use a small dry wall screw and insert it in the hole,twist then pull:),clean all the ports re install and it should run like a champ.if engine still hunts during open choke also try removing the pilot jet by removing the plastic screw then the spacer underneath then pry the jet using the screwdriver this jet is very tiny i would use a bristle out off the wire brush if possible.
Sep 30, 2014 | Honda 13 HP Engine w/electric start - GX...
1975 Honda Cb 400 F do you have to re-jet the carbs if you take out the baffles
Hi, Anonymous if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
cb550 carb jet HELP
Carburator Theory and Tuning
Honda CB400T Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB400 Owner Manual
Apr 05, 2014 | 1975 Honda Cb 400 F
Honda gx 670 chokes and sputters in thick grass or when goose throttle
It sounds to me like the carberator is a little dirty, drain the bowl and clean the main jet. Also while you are there check all the jets and make sure they are open not clogged.
Sep 09, 2013 | V-Twin Horizontal OHV Engine with Electric...
Gx270 honda engine starts and runs short while then shuts off
check for fuel flow blockages including a blocked needle and seat in the carby. Remove the carby bowl and main jet and blow out any obstructions including water.
Mar 05, 2013 | Honda Water Pump Honda Engine
Need to rejet 1999 xr250r for sea level
You will need to go down in # jet sizes on both the pilot jet ( low end ) and the main jet ( top end ) since the air is thinner at higher altitude you will need create more air than fuel. For example if you had a 340 main jet you would go with a 320 or a 325. and the pilot jet would also go to a lower #.
Jul 01, 2011 | 1999 Honda XR 250 R
I need to clean carburetor on 340gx honda pressure washer. How would I do this?
pour large amounts of liquid carb cleaner into the gas tank
Let it run for a couple of minutes then shut it off and let it sit for a couple of days.
Aug 16, 2010 | Honda Garden
I have an 86 honda nighthawk 450cc. the choke has to be pulled most of the way out to run. i am an HVAC tech, not afraid to tear things apart, but know very little about automotive carburators. where do i...
that carb is probly dirty as a pair of dentures--it needs takin apart soaked in solvent and meticulus assembly-somethin ur good at but buy a clymer manual for insurance
Apr 14, 2010 | 1986 Honda CB 700 SC Nighthawk
Hello. i have a honda gsx 160 jet wash...it starts but when i start using the water it shuts down.
Hi
Feb 01, 2009 | Honda 8 HP Engine
Honda 8 HP Engine Logo
532 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
