Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Triniton xbr
Ok so I found one of your solutions for a similiar question and you asked how many times the standby light blinked. Mine just keeps blinking steady no intervals, just keeps going, I quite counting about 50. What happened was my fiance tried to move this huge TV by himself and it didn't work out so well. It fell on him, not very hard but enough that the picture doesn't work anymore. The sound works but the picture looks like the TV isn't even on. Can this be fixed?
    President:
  • 2,992 Answers
The continuous blink code indicates some failure in communication between the computer in the set and the big signal-processing chip that controls most of the TV's video functions. Since the set fell, it's probably due to a either cracked circuit board or a broken picture tube.
If the board is cracked, it might repairable if the broken circuit traces can be found and patched. If the tube is broken (because the shock of the fall cracks the glass neck of the tube and allows air to leak in), it's time to replace the TV.
There's really nothing you can do on your own to fix this. Your best bet is to see if a professional can come out and give you an estimate. (Or use this as an excuse to get new flat-screen which would take up a lot less room!)
Posted on Feb 17, 2009
My Sony Bravia XBR 52in will not stay on and red light is blinking.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 23, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony xbr KV-34xbr910
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 06, 2014 | Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
Nov 07, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron XBR, Stand By Mode?
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
Many of the later model Sony TV?s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article. Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
May 21, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY XBR 60" STANDBY
Check the door for the lamp...over time mine distorted from the heat, and this was an error code for the door now being closed. Temporarilty I wegeded something in there to hold the switch closed, but ended up replacing the door.
Dec 12, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
Apr 12, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
