Question about Optics
I cant find friction adjustment on Minolta 10 x 40 binoculars
Minolta 10 x 40 5.6 degree binoculars They are too loose and need to be tightened up on the central shaft Is this possible I cant see a way of getting the cover off to adjust the friction (tension)
Hi Ray:
I have Minolta binoculars with the same issue, I believe that I also have the same Minolta model: 10x40mm, roof mounted prisms, 5.6 degrees, waterproof (WR series) and model number j-b35.
Have you found any solution for the loose center hinge?
josch799@yahoo.com
Posted on Jan 09, 2010
How do you adjust the friction disk on a 627852X07A snow blower
Is the drive belt too loose? Mine has an adjustment that you can tighten up . Mine last winter was slipping till I tightened the adjustment.
Sep 07, 2014 | Garden
Tighten minolta 10X40 j-B35
Cloudynights person says it was very difficult to get the cap off the hinge so that he could tighten it. He had to hone small screwdrivers until he could pop off that hinge (it is so well sealed for the WR rating, I suppose). Then he could get to the bolt that tightened the hinge so the binos stopped flopping about. I still don't know how he got that cap off, though.
Mar 15, 2013 | Minolta Optics
Eye piece lens detached
Find best compact bird watching binoculars for sale, best compact spotting scope that let you get closer to nature. Welcome to www.falconstare.com.
Aug 20, 2012 | Minolta Optics
Minolta Compact II Binoculars - the focusing adjustment is seized, how do I free it?
The adjusting knob has a rubber cover over it. Remove the rubber cover and take out the phillips head screw underneath. Then turn the adjusting knob all the way left with a pair of pliers and continue turning and it will unscrew and come off. Underneath you will find a metal lock nut, when you loosen this you will find the adjusting knob is suddenly not frozen anymore. It seems that this nut tightens over time to the point where the whole mechanism freezes. You can take the nut off and put some thread lock on the threads and tighten it just enough and it won't happen again. Cheers.
Sep 24, 2011 | Minolta Compact II Binocular
One image is slightly above the other at all distances. After using the binoculars for even a couple of moments, my eyes are strained. The problem was present when the binoculars were purchased, however...
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Feb 13, 2011 | Minolta 10x25 Activa D WP XL Pocket...
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
Jan 31, 2010 | Minolta Activa Pocket Binocular
Binoculars are too loose to hold eye to eye spacing/
under the bottom hinge cover there should be a hinge nut you can tighten, if i can help further call 5088331232...larry
Jun 12, 2009 | Bushnell Binoculars - Off Trail Compact
Head space loose on Peugeot bicycle
Sometimes the topnut works loose enough for the adjusting nut to come loose and then everything is loose. What usually happens though is that the bearings in the cages wear into the cups and you need a new headset. They come in various sizes and types so you will either have to take the bike in or take all the parts from your headset in to get a replacement. You should try backing the topnut off some more and then tightening the adjusting nut down as much as you need to remove the play and still not have any friction while your steering and then tighten the topnut back down. It will require a thin walled bicycle wrench the correct size to hold the adjusting nut in position so that you don't tighten it further while you are tightening the topnut with a second suitably sized wrench. Hope this helps.
Mar 08, 2009 | Cycling
Hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Feb 19, 2009 | Nikon Sporter I Binoculars
Optics Logo
514 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
