Question about Ingersoll Rand 3/4" Super Duty Extended Anvil Air Impact Wrench
Ingersoll 261 problem
Ingersoll rand 261 runs but has no power,have striped tool and everything is ok.tool is less than 2 months old and has not been used till today.any help wecome.
    Problem Solver:
  • 6 Answers
That tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
How to get the guts out of a three quarter inch impact ingersoll
There should be four bolts on the back of the unit, take those of and then remove the cap be careful and watch how everything comes out and put back in, in reverse
Apr 07, 2010 | Ingersoll Rand 3/4" Super Duty Impact...
How do you disassemble a ingersoll rand 3/4 impact completely to rebuild
simple - send it to me i have 30 years experience i worked for snap on tools
Feb 12, 2010 | Ingersoll Rand Ingersoll-Rand 261...
Ingersoll rand 231A 1/2 inch impact wrench no power
if you have already used air tool oil you may have to take it apart and clean the motor vanes
Jan 29, 2010 | Ingersoll Rand 1/2" Super Duty Air Impact...
The compressor trip at main breaker
possible causes , do not use ext. cord on compressor unless it's HEAVY gauge, also if you have any thing else running on the same breaker, It might cause it to pull too much power.
Oct 06, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
IR 261 air wrench vanes sticking
NOT exactly a solution, but may help you with your problem: I'm also a Owner of a 261 ( In fact 90% 0f all my Air Tools are IR) that I used everyday when I was working on Terex Equipment & EMD Locomotives. I "Upgraded" the Major Parts inside my Gun to the "Industrial Line" rather than the Automotive Parts since the 261 is classified as a Automotive Tool..and Installing an Adjustable Regulator on the Gun Helped a Lot too...by "tweeking" my Gun out, I was Pumping almost as much torque as some of the 1" Guns...
FYI: Don't Over Oil as the Oil will absorb into the Vanes, causing them to Expand in thickness "Permanently"...just 2-3 drops of a Hi-Grade Air Tool Oil before starting the Day is enough...sounds to me like your Picking up some contamination someplace??
Feb 05, 2009 | Ingersoll Rand 3/4" Super Duty Extended...
New ingersoll compressor starts slow pops reset
sounds like your non return valve is passing
recheck your readings with an empty reciever
Nov 12, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Ingersoll Rand  3/4" Super Duty Extended Anvil Air Impact Wrench Logo
378 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
