I'm wondering if this is a Drum , transfer belt or fuser issue.
Enter in the service mode and tested in part every colors.Press Utility key - Meter count - Details - Stop 0 0 Stop 0 1 select test pattern gradation test select the colors and press Start key(the test is make A3 paper).If the test is OK verify the transfer belt unit and the transfer roller unit.If the lines appaire on the surface the transfer belt clean the belt cleaning blade and the cleaning brush used a vacuum cleaner.Clean used a special long tools under every image unit LED lines.
