When I push the start button on my Maytag dryer it sounds like it going to start but doesn't kick over. The button will let me keep trying maybe 5 times and then I smell a hot smell and stop trying. Last week it would start on occasion but I had to hold the button for a longer time then I normally had in the past. It was happening periodically over the last few weeks but I have not gotten it to "connect" but once in the last 3 days. When it connects the dryer runs through the normal cycle. Any ideas??
SOURCE: maytag gas dryer
This is valid for a Maytag Neptune MDG3000AWW Gas Dryer (I am responding to a problem which was mis-identified as a MDG5500AW Gas Dryer)
NOTE: Motor problems begin intermittantly. They can be temporarilly fixed by blowing out the motor with compressed air. Eventually ALL motors fail. In my case, with six kids it took 10 years for our Maytag motor to fail. YMMV.
MOTOR REMOVAL INSTRUCTIONS
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
a. Remove the door and opposite side door plugs (crosstip screws)
b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
c. Unscrew all the exposed bolts.
d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
e. Release belt from pulley by reaching left and under drum (this is out of sight)
f. gently lift out drum and belt and set aside
Observe the motor. Listen and smell. IF you see smoke from the motor, or IF you hear a "starting sound" but the motor itself doesn't spin, is very slow to start spinning, or makes racket, or it made a noise and then stopped... THEN your motor is burned out. Confirm by sniffing the motor. IF the motor smells burned, THEN your motor is burned out.
NOTE: If your motor is burned out it CANNOT be fixed because it is a "double wound motor." The motor must be replaced.
To replace simply reverse these instructions. GOOD LUCK!
SOURCE: Maytag Neptune MDE7500AYW - Won't start - Message says "A power failure..
I had the same problem. It turned out a power transformer in the neighborhood had gone bad. I found it by checking power at the receptacles in the house and we weren't getting proper voltage throughout the house. We had enough power in the house to power lights, the TV, coffee maker etc. but not enough for the dryer. I called the power company and they came out to do a check. At first they said there was a wiring problem with the house until all the neighbors started coming over after seeing their vehicle and saying they were having problems. So maybe you aren't getting proper power to the unit.
Good luck. Hope this fixes your problem.
SOURCE: Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
SOURCE: MDE5500AYW MAYTAG DRYER WON'T START
pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
SOURCE: Maytag Performa Electric Dryer Won't Start
Replace the thermal fuse and the high limit switch.
They come as a set.
Clean the auto dry sensor with rubbing alcohol.
