Question about HP Photosmart R817 Digital Camera
Camera locked up
Somehow, the camera is locked up. It seems that the lens is part way out and will not go to home position. I thought it was just an extremely low battery, so I bought a new battery. Same result. When you fire it up, the HP screen comes up and then it immediately turns itself off again. I have tried resetting the camera with the little button, but no dice. Any ideas?
  • Anonymous Jul 01, 2008
    I have exact same problem ... lens locked up half way open , and when power is turned on .. soon will shutt off again .... any solution or is it best to buy new camara?? PLEASE REPLY , i really liked this camara very much PLUS i have all accessories for it! What a waste!
  • Anonymous Jul 07, 2008
    I have the same problem the lens is out and will not retract and when you try to power up the camera it shuts down. I tried turning the out lens ring like mentioned in an early post, but no luck.
Having had the same problem and out of warranty so not worth paying for repair, I actually forced the stuck lens back into the camera as I thought i may have to trash it anyway and it worked!!
Posted on Aug 26, 2008
I have the same problem but instead of being out it turned to be in, and when I turned it on , it goes like the lens had some thing in it's way so it stop. any solution !!
Posted on Jul 13, 2008
I had exactly the same problem. It seems it can happen if the camera tries to open the lens when inside the case. The solution in my case was to grab the outermost metal ring of the lens and twist it clockwise (gently but with enough force). I heard a snap sound as the lens clicks into place and after this the camera started working.
Posted on Oct 30, 2007
    Genius:
  • 2,985 Answers
Lens motor shot? Checkout the customer support at HP However if it is out of warranty I guess you will find the price of a repair is well on the way to the next camera
Posted on Aug 01, 2007
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
Zoom is stuck
There is a reasonable common fault where screws internally come loose and cause the zoom to jam - you will need to get the lens serviced.
May 30, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
There is dust on the inside of the lens of my nikon coolpics L1. can i get in there somehow to clean it?
Google the words...disassemble a digital camera. When you finish going to a couple of the sites, you may change your mind about trying to take your camera apart.
Dec 21, 2009 | Nikon Coolpix L1 Digital Camera
Mirror is stuck down
if it its just a perticular lens then its because the body cannot comunicate with the lens to disable the lens lock Press and hold DRIVE MODE and AV buttons while turning on camera.
Jul 27, 2008 | Minolta Maxxum 400si 35mm SLR Camera
Flashing " F EE" in the control panel
The setting should be the the other end of the scale, I.E. f16,f22. The lens needs to be at the smallest aperture opening size, not the wide open setting. The lens does have a small tab that will lock the ring in that position.
Jan 13, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Digital camera says sim card locked
If this is an SD card you may need to take out the card and slide the small switch on the card itself to the "Unlock Position"
Good Luck!
Jan 01, 2008 | Cameras
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
HP Photosmart R817 Digital Camera Logo
179 people viewed this question
Top HP Cameras Experts
Harrie
pontelemon
pontelemon
Fred Sops
Are you a HP Camera Expert? Answer questions, earn points and help others
