Question about Mercury P4VM800M7 Motherboard
Front panel audio pins
I am not able to insetr the pins form my headphones. there is a difference in between pins disription and in mother board and mother bard case pins. how can i do this
  • venkateshs May 11, 2010
    check for sutaible headsets
  • 152 Answers
Posted on Feb 02, 2009
No sound in front panel and even pop message not coming on pluging in headphone in front panel of newly installed mother board
The front panel audio jacks are not connected to the motherboard. Take the computer to the service who installed new motherboard and tell them your problem!
May 16, 2011 | Gigabyte GA-P55-UD3L Socket 1156/ Intel...
No headphone connect
hi gangster. you don't headset pin in your mothreboard , just get audio card in hardware shop and fit it to your motherboard and instal it , you have headset pin in audio card.( Audio card cost starting form 6$ )
Now usb audio drive also available in market just buy and plug it in USB port and plug your headset in that port.( Usb Audio card start from 3$)
Good luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hook up for the audio on the front panel
When you are looking at the motherboard with the CPU and memory slots on the right, the audio hookup is up on the edge of the motherboard on the left. It's the last set of pins in the upper left side of the motherboard. If you have an audio jack in the front of the machine, you should have an audio cable just hanging there somewhere that is not hooked up. Hook it to the audio connector that I described.
Jun 10, 2010 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
Hi, my mother board is HP d530 SFF ...i installed the correct audio drivers and its shows no problem in software ...but still i m not getting sound from my back pannel.can any one help me how to connect...
There is "Front Panel Audio" connector on mb. If you don't use orginal connector from orginal case you must short pins on mb.
2 o o o x o 10
1 o o o o o 9
If you short pins 5&6 and 9&10 you should have sound at rear audio panel of mb.
I have run into this on a different compaq model in a different case. It maywork for you but must find small jumpers if they are not supplied. No guarantee but worked on my compaq d530
Aug 05, 2009 | HP D530 PC Desktop
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
Front panel for sounds is not working, ports for the front panel has 5x2 ports but my audio pin only has 4x2
MY ASUS M2MN SE MOTHER BOARD FRONT PANEL AUDIO & MICROPHONE IS NOT WORKING, I WILL REPLACE A NEW FRONT PANEL BOARD, BUT STILL NOW SUFFERING SAME PROBLEM, PLEASE GIVE ME A SOLUTION ON MY E-MAIL, THANK YOU.
SEKHAR CHAKRABORTY E-mail: chakrabortyentp@yahoo.in
May 22, 2009 | Biostar GF7050V-M7 nVIDIA GeFORCE 7050...
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
