Question about Garden
Replacement of a pull cord on a ryobi petrol strimmer
Have recently purchased a petrol strimmer - how do I replace the pull start cord.
Many thanks.
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
  • 5 Answers
SOURCE: Starting problem with a Ryobi rlt30ces petrol strimmer
Hi
I have had the similar problem & spent a day stripping the unit down
(dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....
Check also that little gauze air filter behind the roto choke is not blocked.
this solved it for me.
Please remember to give me a rating ...ta
Posted on Feb 05, 2009
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
SOURCE: trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
Posted on Jul 04, 2010
vincob
  • 718 Answers
SOURCE: mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Recoil pull cord wont retract.
Buy a new part unless your capable of taking apart the motor and restring it
Jun 28, 2014 | Sony PlayStation 4
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
How to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Sep 04, 2009 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Hi
Jan 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
3,944 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
