Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore gas stove control panel not working
We have a kenmore gas stove mod. no# 790.75751103, burners lite oven lite comes on both with switch and opening door. The complete controll for oven, time and other settings are black. Its the touch pannel it dose nothing,. Warming oven lite comes on but nothing happens. Please help I really need my oven this happened all of a sudden.lites just went out.
  • 15,935 Answers
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
My kenmore electric oven works on the 4 burners on top, but the oven part does not heat at all.
There is an upper and lower burner, since it's not heating at all it's either your gas control valve or your temperature control board.
Note: If you have Sears service come out to repair your stove beware, We had them fix our stove. They told us there would be a $65 charge for them to come out but if we had the repair done it would be included in the repair price. Instead after they had our stove torn all apart they told us we would have to pay both charges or they would just leave with our stove in piece and we would still owe them the $65.
Jun 11, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Jul 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
I have a Kenmore Range, this op of the stove is liting but the over is not heating, you can smell gas and see the red burner come on but no heat
Hi!!! you seem to have a bad ignitor on your stove.just remove the lower inside panel of your stove and remove the glow ignitor easy to install.a quick fix.good luck..
Jan 03, 2009 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My oven doesn't work but the burners do, what's up with that?
I was looking for a solution to my problem. In reading the comments, I can probably provide more information than is given here. My Kenmore gas oven won't ignite. I have over 25 years as an electronics techincian so I am very aware of lethal voltages. I unplugged my stove, it is a 120 volt model. After pulling the panel off so I could get to the thermostat which is the piece the knob goes on, I plugged the stove in and checked to make sure I have 120VAC to the thermostat. I have a red wire which has 120Vac, the thermostat probe wires, and a yellow wire which goes down to the back of the oven.
My red wire had 120Vac. I then unplugged the stove, very important at this point, and meaured with an ohmmeter across the yellow and red wires. When the oven is in the off position this is open. When I turn the oven on it is shorted. That should confirm the thermostat switch works. The next thing that has to happen is the glow bar/igniter has to glow. This is like all gas appliances, it has to glow to heat the gas valve and turn the gas on. My igniter doesn't glow so I ordered a new igniter. If your glow bar glows, it could still be the glow bar/igniter or the gas valve is not allowing gas to flow even after it is heated up.
If anyone sees a problem with this procedure, please let me know.
Nov 19, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
202 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
