Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Liftmaster 4210- motor runs just for a couple of seconds-
Green light then flashes on back of unit. Have just replaced plastic gears, and put it all back together- must have done something wrong!
Can you help?
Thanks,
Eric
  • marty metzger May 11, 2010
    electric eyes. Light on unit flashing. what is door doing. I ignore led lights on board.
  • 118 Answers
You need to sync the door with the limits.
Posted on Feb 09, 2009
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door won't open. checked chain, seems to be ok
The problem is not the chain, it is the plastic gear in the unit of the liftmaster Garage Door 1/2 Hp.The plastic gear is not engaging, although it sounds like it is working.
You will have to replace it with a new one, then the liftmaster Garage Door 1/2 Hp will be able to open up once again.
Once you open and remove the old gear, Be sure to thread the screws in all the parts before you install them. Pre-threading them once would really help. Secondly, label the wires on the back of the opener before lowering it to the ladder, so you can put them back in their proper place.
Hope this was helpful.
Goodluck
Elect_Comp
Jun 27, 2011 | liftmaster Garage Door 1/2 Hp
Craftsman GDO don't not respond other than a click noise when remote or wall unit is pressed. When power is removed, then restored, wall switch is pressed, unit clicks, then green LED on back of unit...
The unit is flashing the code for 'motor overheated or RPM sensor failure'. If the door is stuck in the open position it could be because the trolley is jammed against the bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now on the side of the motor unit you will find the 'up limit' adjustment. Turn this 2 full turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have Chamberlain LiftMaster 1255R garage door opener. The electric eye does not lit and the opener unit flashes 5 times and then off. Do you know what the problem may be?
My garagedoor opener is not working.
I open the box and found the plastic gear worn out.
I have Liftmaster 1255R.
Do I need to replace the whole box or replace the worn gears?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster 1246R won't open/close
if youcan hear the motor turning when you hit the remote or wall button the plastic gear in the oprator has been ripped and if you take the cover off you will see all of the whote plastic dust that has come from the gear being shreded. You can replace this gear. you do not have to buy a new operator. it is very easy to replace this gear. I can't tell you were to buy one because I buy all my stuff from a dealer.
Jun 09, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster 1/2 hp won't open
Turn the gears again by hand like you did and lower the door a couple feet. Now find the 'up limit' on the side of the motor unit and using a small screwdriver turn this about 3 turns in the opposite direction of the arrow printed on the cover. Now you can go ahead and operate the door.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
5 blinking lights
The code for 5 flashes is RPM sensor or motor overload. Did you remember to put the black plastic interrupter cup on the end of the motor shaft? Also check the small quick disconnect on the RPM sensor printed circuit board. Make sure it is connected securely.
May 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Garage door opener will not work up or down,light is on.
take off console )disconnect wires). if remote works, get new console.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
301 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
