Question about Homedics Deluxe Automatic Arm Blood Pressure Monitor
Reading EE My husband and I both get that reading everytime,nothing we do changes it we are evry careful not to move but it pumps up and then deflates down aways then all the way to EE
  • 50 Answers
The cuff sensor must be placed directly over the vain. This takes practice.
Posted on Feb 06, 2009
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Apr 14, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
How do I input a problem using log
What does it give you? What is this 10exp11?
If you want to enter 7.8X10^11 type it as 7.8[EE]11. [EE] is the key [Exp[, or [EE] or [x10X]. The EE is a short cut for *10 to a power. The 10 must not be appear in the expression entered.
Nov 20, 2013 | Sharp ELW535 Calculator
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
I don't know how to deflate a air mattress with a electric pump. the brand name of the bed is lit-minute
I was looking for the same question and these two links useful
Hope this helps...
Feb 22, 2013 | Furniture
How do I inflate/deflate my water trampoline?
You can inflate your water trampoline with either an electric pump or a manual pump. I suggest using an electric pump because it will save you a lot of time and effort. In terms of deflating, you also have 2 options. You can simply open the air valve and allow the tube to self-deflate or use a two-way air pump to remove the air.
Jul 31, 2012 | Sport & Outdoor - Others
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
My Walgreens Digital Blood Pressure Monitor pumps up to diastolic 118-122 then stops and deflates and the screen reads Err 2. Can you please tell me what the problem might be? Thank you.
Your Blood Pressure may be to high for the reading. Try to adjust the cuff and restart. Are you sure it is diastolic reading and not systolic?
Jan 13, 2011 | Health & Beauty
I have a Coleman Guest Rest Sleep System and I cannot get the air out of the mattress. I have taken the pump out of the casing and inserted it in the hole for deflating and I can't get it to work.
Is it battery or electricity operated? You might need to replace the battery or hook it up to the right outlet. Follow the instructions in inserting it to the hole. Make sure you press the deflate button and not the inflate button.
If the pump device is really not working, you can temporarily manually deflate the air bed by unhooking the air release nozzle. Press it slightly to allow the mattress to deflate faster. Step on the mattress lightly to force air out a bit.
Aug 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Getting a F EE reading
Having received no response in over a month, I assume this is no longer a problem.
Apr 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
When deflating gives error signal - EE Request service center address (Phone number in India.
Hello. Here is the contact page link
It appears that the nearest location to India is Singapore.
please rate my answer as very helpful. thanks Joe
Mar 26, 2010 | Omron Automatic Blood Pressure...
Homedics Deluxe Automatic Arm Blood Pressure Monitor  Logo
361 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
