Question about LG 42LC2D 42 in. LCD HDTV
AKAI 42"LCD TV MONITOR opens into colorful plds. and stripes.
I have an AKAI 42"LCD TV MONITOR les than 2 years old that opens each morning into a colorful range of plaids, stripes and a box in eack corner of the screen. After about 20 mintes by turning it off and on a few times it goes into white stripes that eventually disappear into a rough grainy picture for the rest of the day. HELP. Who do I call to service this problem in the 13206 zip code area.?
Etaddeo2@twcny.rr.com
  • LG Master
  • 19,396 Answers
The problem is a defective video chipset, they need to replace the digital board to fix this.
Posted on Feb 01, 2009
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
Large verticle stripe on the left hand side of a 40 inch Samsung LCD TV. One can still see the picture & hear the sound on the rest of the tv. Stripe changes color periodically-goes from a solid to a...
you need to find the broken contacts on the offending matrix controllr and resolder it. Not for the faint of heart if your soldering skills aren't good!
Mar 08, 2011 | Televison & Video
42 inch HL167 has nothing but colorful streaks
Probably a bad T-CON or LCD controller board, Toshiba calls it a "Seine" board.
Parts are available here www.shopjimmy.com
Feb 17, 2010 | Toshiba 42HL67 42 in. LCD Television
At certain times i get a thin stripe down center of tv . its less than 2 years old.
thats a panel display problem. thats a vertical line
need to replace the panel
Jan 08, 2010 | LG 42LC2D 42 in. LCD HDTV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
LCT42Z6TM
My tv is almost a year old also. Having the same problem as others with the squares. Sam's Club saids it's out of their hands. You paid that much for a tv somebody should be responsible for their workmenship lasting longer than a year.
Dixierose77
Apr 17, 2008 | Akai LCT4216 42 in. LCD Television
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
LG 42LC2D 42 in. LCD HDTV Logo
61 people viewed this question
Computer Repairing
Computer Repairing
