Question about Kodak EasyShare C743 Digital Camera
Cracking sound My camera started making a loud cracking sound and I can also feel it right under the silver decorative line. It does it at random but frequent times. Moreso after or during taking a picture. The flash no longer comes on automatically either. I have to press the redeye button at the top every time I take a picture. What could be causing this and how do I fix it? Thanks :)
  • Charlotte Leto Aug 01, 2007
    oh man :( Thank you for your help :) There's no way to fix it myself huh?
  • Charlotte Leto Aug 03, 2007
    ok thank you so much for all your help! :o) I guess I'll have to take it to a repair person. Do you know offhand if this tends to be an expensive repair?
    Genius:
  • 2,985 Answers
There is short in the flash section. This is a potentially dangerous voltage and could give you nasty jolt. Contact Customer service immediately
Posted on Aug 01, 2007
  • john ash
    john ash Aug 02, 2007
    Absolutely not.
    If this is a new item return it to the seller or contact Customer help at Kodak
  • john ash
    john ash Aug 03, 2007
    Check out the Kodak Website customer support.
    Depending on the age of the camera, Kodak will either exchange it for another or offer a good discount on a new one.
    A repair is not an option with this type of thing.
SOURCE:
I have an 05 Mazda 6, when my car is while idling it makes a loud cracking/popping noise.
A cracking or popping noise is frequently an indication of an air/fuel mixture that is too lean (too much air). Have a mechanic or mechanically inclined friend check the various vacuum lines on your engine. Sounds like a cracked or broken vacuum hose on the intake side of the engine. Good luck.
Oct 10, 2013 | Mazda Cars & Trucks
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Random radio cracking sound
Cracking sound is usually electrical interference but from where (in your case) I can't say.
Apr 22, 2012 | 2002 Porsche 911
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
BELLING 552 ENFIELD/S front panel with gas on/off buttons on it, the silver paint under the lacquer is cracking
having reported this problem to comet the cracking of paint got worse and started to crack also on the grill door,
comet replaced the parts, after about 10 hours use on one gas ring and a small amount of use in the grill the same problem started again.
Apr 17, 2008 | Belling Kitchen Ranges
Coolpix 4300 problems
hi sounds like your baby have had a good introduction with something more hard then it.... clicking sound - the delicate mechanism is misplaced(cogs slipping) lens cracking.... nothing to do but hope for warranty im sorry good luck
Apr 27, 2006 | Nikon Coolpix 4300 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
60 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
