Question about Mitsubishi VS-60607 TV
Mitsibishi VS-60607 TV won't turn on and remote won't work now.
I was playing a video game last night and when I shut off the game console, the TV randomly changed inputs and wouldn't shut off. I tried the remote and it didn't work eiter so I tried pushing the front AV reset button and still no help. I unplugged the TV to shut it off. This morning I tried to turn it back on and nothing would work to turn on the TV. I replaced the batteries in the remote but nothing woill get it turned back on. It has happened a little in the past and pushing the AV rest always did the trick, but now it won't. I need help before the Super Bowl game today if I can get it.
  • 2 more comments
  • unlockme Feb 01, 2009
    Which IC and do I need to replace the whole mother board or just the IC? Could you be a little more vague???
  • unlockme Feb 03, 2009
    I unplugged the TV last night and plugged it back in this morning and it turned back on. I am afraid to turn it back off now. There are no lights on the front panel, blinking or otherwise, except when it came back on. I checked all 5 fuses on the board and they are good. I was told the 2 convergence ICs were bad, but I don't understand how convergence ICs have anything to do with the power or remote problems. I hate to shotgun parts into this problem, if you know what I mean. Any other suggestions?
  • unlockme Feb 07, 2009
    I was playing a video game last night and when I shut off the game console, the TV randomly changed inputs and wouldn't shut off. I tried the remote and it didn't work eiter so I tried pushing the front AV reset button and still no help. I unplugged the TV to shut it off. This morning I tried to turn it back on and nothing would work to turn on the TV. I replaced the batteries in the remote but nothing will get it turned back on. It has happened a little in the past and pushing the AV reset always did the trick, but now it won't. I need help before the Super Bowl game today if I can get it.
    Comment posted on Feb 01, 2009
    Comment posted on Feb 03, 2009
    I unplugged the TV last night and plugged it back in this morning and it turned back on. I am afraid to turn it back off now. There are no lights on the front panel, blinking or otherwise, except the green power light, when it came back on. I checked all 5 fuses on the board and they are good. I was told the 2 convergence ICs were bad, but I don't understand how convergence ICs have anything to do with the power or remote problems. I hate to shotgun parts into this problem, if you know what I mean. Any other suggestions?
  • Mitsubishi Master
  • 19,396 Answers
If you unplugged TV and plugged back, and now TV is fine, the problem is sorted.
Unplugging the TV is called hard reset and sort out problems related to electrostatic charges on internal circuits and bad settings problem by draining power off TV completely.
The original problem was probably caused by some jammed capacitor on the HDMI input on TV.
To prevent problem in the future:
Always plug and unplug HDMI devices with TV off.
Do not let a plugged device (EG your game console) plugged to tv for a long time while the set is off.
Use good quality HDMI cables (eg. monster cable).
Regarding the IC, some of the experts here are not really technician, and post their hint as a regular user could do. To makle it simpler , the IC was pure rubbish and the guy did not have a clue of what he was talking about.
What you should have done from start was just unplugging (hard reset) and then following suggestions above.
Posted on Feb 07, 2009
  • 15,935 Answers
You may need to open up the power supply and check for cracked solder joints on the board.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Let's try the simple ones first:
  • unplug from the mains for an extended period of time;
  • check that none of the buttons on the front panel control is stuck.
Pls postback results. Good luck and thank you for using FixYa.
Posted on Feb 01, 2009
    President:
  • 2,559 Answers
Try a hard reset,(Unplug for 4 hours and then try it.)
If a hard reset doesn't do the trick,
It sounds like it might be a loose contacts on the power module relay.
(This can sometimes be tested by hitting the unit with the palm of you hand in a few different locations while try to turn it on)
    Genius:
  • 1,011 Answers
Sir,
i think the problem with continuous running the tv. may be the capacitor burnt out. Is there any light blinking? check what type of error code it displayed. Also try to hard reset the tv. unplug the power for 24 hours.
check this forum for more help
thanks
good luck
    Sergeant:
  • 250 Answers
As it can be possible that the ic or the capacitor on the main board of the tv are going to blow out as due to getting faulty.and while you shut it off the game console.at that time it actually got short circuit.and tv did not start .its advisable to check out the board of the tv with a meter first and locate the faulty component.and replace them.do not on the tv till it gets checked and repaired.as it may make some more damage to the components due to this.u can get the parts from
radioshack website.
    Sergeant:
  • 326 Answers
If there is a blinking on the front pannel of the tv then its ic on the main board of the tv.you will have to check out that with multimeter to lpocate the faulty ic as there r many on the main board.but if the light on the frontpannnel is not coming on then its the small $2 fuse which it blown out.its on the main board.get it replaced.
  • 916 Answers
Does it make any noises? Do you hear any clicking sounds? Does the the light on the tv blink at all when you try to turn it on?
  • machadojr_fe Feb 01, 2009
    If you see no blinking or no indication of power what so ever then you will need to replace the power supply to get it working again.
    President:
  • 2,110 Answers
It is the prob with one of the IC's on the MB get it replaced n everythin'll b fine
I have a Mitsubishi VS-60607 Tv and it started out
Without going in with troubleshooting equipment it is hard to determine if the problems are related or not but it is unlikely since you seem to have a video problem and a convergence problem , which are two separate circuit(signal processing and deflection). Hope this help.
Please do not rate this answer(unless it helps)as it is only a suggestion.
Dec 03, 2009 | Mitsubishi VS-60607 TV
I was playing last night and it just shut off i
Id probably bring it to game-stop or have someone else come to your house to fix it
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Wii remote not working
Check the sensor position, whether it's on, and how far away you are from it Wii remote sensors a can be really annoying
May 20, 2009 | Nintendo Wii Console
My son was messing with the buttons on my big screen and now theres a big black box in the middle of the screen.. when i turn up the volume it goes away but when you dont press any buttons it goes back..
well u have that there because... he massed up the menu like in those tv's there is a option if u wana do 2 things at one time like watch the tv and play video game so basicly there is nothing wrong with thee tv.. u have to go through the menu to shut the second screen off.. its probbaly for video 1 or video 2..!! just go through the menu one more time and go on every option u can and u might find it..where it says u wana turn the video screen off
Jan 15, 2009 | Mitsubishi VS-60607 TV
My VS-60607 won't turn on
unit will power on for a second then shut off. power supply ?
Oct 27, 2008 | Mitsubishi VS-60607 TV
Wii controllers
check your infred bar make sure it's pluged in and in view
Jan 11, 2008 | Nintendo Wii Console
Mitsubishi VS-60607 TV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
