Question about Refrigerators
MY ROPER REFRIDGERATOR IS MAKING A LOUD NOISE. POSSIBLY THE FAN OR COMPRESSOR? WHAT CAN I DO TO QUIET IT DOWN?
  • Refrigerators Master
  • 4,655 Answers
First find the area the noise is coming from. Does it sound like a fan hitting something? Or is the compressor making the noise? Has dust collected in the condenser coil area that has cause air restriction ? I a paper shroud that is mounted near the fan come loose and striking the fan? Has the noise affected the performance of the refrigerator? Let me know and I will be able to help you solve this.If you find the problem please remember to unplug the refrigerator before putting your hand in an area that could cut or shock you!
Click link below to get more problem solving answers. And if I can help let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
LG LFX25991ST Linear Compressor Frig has started making a noticeable audible (vibrating?) noise.
There are instances where the compressor can come loose inside its housing. That is not an indication that it is going to totally fail and it has no effect other than the noise. The fan noise would be louder inside the fridge. It would be a squeal.
Jan 07, 2018 | LG Refrigerators
Noise
There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Apr 22, 2014 | Haier 65-Pint Dehumidifier
Our ac unit is making a loud noise and there is water coming into the house via the vents. we cleaned out the vent and took some of the water out of the middle pan and the outside pan, and it doesn't...
My recommendation would be to have some one knowledgeable in refridgeration come in and take a look. You make have more than one problem going on. However the water build up can be due to a plugged drain line. Try using a wet and dry vac to clean the drain line . the fan noise may be the fan motor bearings. If this is the case you can remove the fan and possibly have bearing installed but most likely will need to replace the fan motor
Jul 07, 2011 | General Air Tools & Compressors
My old side by side Kenmore with Icemaker makes a loud rattling sound when it stops running. It is the existing refridgerator from when we bought our house so I don't have any warranty info on it. Any...
If the noise is loud enough that it sounds like somone knocking at your door then it is probably going to be the compressor. There are internal springs and is possible one broke. The only solution is to replace the compressor. It is also possible that the condencer fan motor is hitting something as well when it shuts off. You would have to look at it from the back as it shuts off after running.
Nov 02, 2010 | Kenmore 53642 / 53644 Side by Side...
We have a bottom freezer Kenmore refrigerator, and it makes a very loud tapping noise, almost like someone hammering. Then it will make on loud pop and quiet down for awhile.
Which is your model.
Also how about cooling temperatures are they ok.
Is the sound like the motor compressor hemmering or the fan blades hammer.
Oct 28, 2010 | Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Refridgerator Noise
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Dec 26, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
