Question about Hotpoint NWXR473EV Dryer
Tumble dryer makes whine noise but doesnt spin
Hotpoint aquarius ctd00 . when i turn it on it makes a whine noise but dryer wont spin . if left on smoke comes out dryer . can see red glow through holes at rear of drum. please help!!!
  • Hotpoint Master
  • 3,463 Answers
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
The noise could be .... the drum sometimes has stick on metal pads for balance or heat shields that will come up and start smacking on the cabinet of the dryer. Remove or lift the top of the dryer and turn the drum and looks for these pads. if one has lifted either glue it back or cut the part off that has lifted.
As far as the not drying part ..... it could be that the dryer is just getting tired and the heating element is gong bad or it could be something as simple as cleaning out the vent going out of the house. You can do this by disconnecting the dryer from the wall and blowing it out with a leaf blower or having someone come in and do it professionally.
Hope this helps.
Nov 25, 2013 | Washing Machines
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryers Logo
667 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
