FixYa.com
Tags:
NAD 712
NAD 7140
posted by starrider on Aug 01, 2007
The unit powers up but even with the volume turned to the max position you here the music very faintly. All three fuses are ok. I hooked the speakers to both A & B ports but get the same results. Also does not matter if it is in the CD or Tuner position any ideas. Please Help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
wingnut
Rank:Wiz Wiz
Rating: 80%, 128 votes
Amplifier is about shot, need to replace IC pack or transistors (whichever it has). Could, remotely, be the speaker lines are installed incorrectly?out of phase. + to +, - to - from amp to speakers. Some amps will protect themselves when this condition occurs till fixed.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Receivers problems?
NAD 712
NAD 7155 with one speaker...
Found no info on this site for... Answer This...
NAD 712
NAD 712 Display unit
Karl, did you ever sort out... Answer This...
NAD 712
Display not working for NAD...
Tuner works and plays fine,... Answer This...
NAD 712
NAD 214 - replace relay
Hi, read you comment with great... Answer This...
NAD 712
LED Lamps and 450 Remote
My lamps are burned out and the... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
