Question about Dryers
Door lock not working.Have replacement part but don't know how to
Take old lock out and replace with new
  • 640 Answers
Just push old latch in ,,it wont hurt,,and pop new 1 in
Posted on Feb 12, 2009
Hyundai ix35 2012 window lock stuck. passenger window half down and cant get it to move up or down
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
Sep 12, 2012 | 2011 Hyundai ix35 2.0
Tip
How to Replace Door Locks in Cadillac cetera car?
The procedure to replace the door locks in car is as follows:--
1) First of all carefully remove the arm rest and any speaker covers if speakers are connected.
2) Then remove the door panel. The door panel is connected by plastic clips.
3) Then remove the door handle screws with the help of screwdriver.
4) After the screws are removed the door handle will come out
5) Now the interior doors handle needs to be removed. the interior door handle is fitted by plastic clips you can use a pliers to pop out the plastic clip, then twist the clip to allow the interior door handle to swing free and easily come out.
6) Take the door handle out
7) Now in the door remove the rod from lock core.Then remove the two bolts holding the door handle assembly.
8) Now before removing the old door lock, please take note of the position in which it is placed. So while inserting new lock there is no problem about placing the new lock.
9) Insert the new lock carefully to the proper position. And reverse/refit all the parts which you removed while replacing the old door lock.
This will help. Thanks.
on Mar 25, 2010 | Cadillac Catera Cars & Trucks
Tip
How to Replace Door Locks in Eagle Vision ?
on Mar 25, 2010 | Eagle Vision Cars & Trucks
Tilt patio door - lock doesn't work
The warranty is with the fitting and glass only. Not the furniture or fittings.
There are many double glazing techies out there that specialise in repairing. Give them a call, you may well be pleasantly surprised.
A standard full height door lock mechanism, called the engine, can be bought for as little as £45. Fitting takes an hour so say £30 call out could be whatever, cups of tea tend to reduce the price, especially when Digestive Hob Nobs are involved!
Sep 03, 2017 | Cars & Trucks
Parts question
I don't know if your talking about a big bronco or a bronco ll. I'm really not sure about the difference in sheetmetal, you may have to take off the old door & match it up with the replacement door. As for the windows and locks, as long as both doors had power locks & windows, make sure the replacement door still has the window glass in the door assembly. You may want to take the time & test the motor on the new door, finally make sure your wires will connect with replacement door.
Jul 06, 2010 | 1990 Ford Bronco
Tip
How to Replace Door Locks in Avanti convertible ?
on Mar 25, 2010 | Avanti Convertible Cars & Trucks
Tip
How to Replace locks in Door Locks of Acura Integra car
on Mar 25, 2010 | Acura Integra Cars & Trucks
Replace drivers door due to crash. old door had 3
You have to examine and compare the two doors. I am just guessing but I would bet that it is the power mirror that your new door is lacking.
Just follow the wiring into each door.
1. Power locks wires should run to a region near the latch mechanism.
2. Power Windows wires should run to somewhere in the middle of the door.
3. Power mirror should run almost straight up towards the mirror assembly.
If it is the power mirror assembly you should be able to transplant your old one provided that it is not damaged.
If it is power windows, adapting power windows will be much harder as the new door may or may not have the provisions for mounting the regulator, etc.
If it is power locks you may need to transplant the latch and actuator assembly along with its wiring.
Jan 25, 2010 | 1991 Honda Accord
Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Feb 05, 2009 | 1998 Jaguar XK8
Dryers Logo
32 people viewed this question
Top Dryers Experts
