Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Error in windows installation
When i tray install windows xp zen I recive error raport:cen't copy file ameehgx3. sys in c://$win_nt$=bt//ameehgx3.sys.The file is missing.Can I ignor tnis file?
  • 34 Answers
Generally you shouldn't skip files try ejecting the disk, cleaning it with a soft cloth place it back in and hit retry.
Posted on Feb 01, 2009
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
WINDOWS 7 to WINDOWS XP
hi you have to use a sat win xp to install it on your p c.get back to me if you did get it
Jun 18, 2017 | ASUS Notebook
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
XP Installation and win32k.sys
hi,
this problem is occured due to corrupt or scratched disk.
u need to install XP with new bootable disk.
Sep 18, 2009 | Microsoft Windows XP Professional for PC
I am having trouble running setup on my desktop
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
Windows installation issues
Either you have a defective CD, or a defective Hard Drive, or defective memory. Firstly is this a clean install? Try reformatting the drive and running chkdsk or a manufacturers disk utility. Then remove fingerprints and other marks from CD by wiping from the centre outwards. Let me know how you get on.
Apr 27, 2008 | HP Compaq dx2000 Microtower PC Desktop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
