Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Motor runs but door does not open
I have a 1/2hp Sears Craftsman garage door opener for a single door garage. When I went to open the garage the motor ran but the door did not open. So now when I press the button all I hear is the motor running but the chain does not move and the door does not open. Thanks
  • 11 more comments
  • CROIX01 Feb 01, 2009
    last cold snap my wife was opening the garage door and it quit half way. The motor runs through a cycle but the sprocket does not turn which turns the chain. I have looked inside but see nothing wrong other than the plastic or nylon gears may be worn out as their are strippings laying inside. At first the chain moved part ways and would quit. Any ideas? It sounds nearly the same as the person I read I am responding to.
    email at rlindblom_2000@yahoo.com
  • RFJones Feb 07, 2009
    I have the same problem where I can hear the motor run but it does not move the chain.
  • skatona Feb 09, 2009
    Same problem. Motor runs, chain does not move. Unit is 8 years old and can't find the owners manual. Where can we see the gear and sprocket kit? What is the cost? Is there an on line manual with instructions or even part numbers?
  • wcraighead Feb 17, 2009
    I have a Sears Craftsman 1/2 hp garage door opener with a date of 2/00 and have the same problem as the others listed here. I am not so much a handyman as much as an anti-handyman:) Where would I get a gear and sprocket kit? And where can I get a basic outline on how to replace it? Thanks in advance.
  • LCM77 Feb 18, 2009
    Is this a conspiracy, I have the same exact problem with a unit built in early 2000 and yes when I removed the cover I could see that the plastic gear was all but worn out. Can someone with limited mechanical skills fix this or should I give up now and flip the bill for a new one ?
  • jbarile Feb 18, 2009
    motor runs but nothing happens. the unit is only a year old
  • mjd30 Feb 24, 2009
    I have a Sears Craftsman 1/2 hp garage door opener 139-53606 the date is 1996 and have the same problem. I found this info and I am going to try and fix it this weekend or next.
  • Anonymous Feb 27, 2009
    how much is a new sproket and gears for the craftsman gaage door opener, any ideas?
  • mark635 Mar 15, 2009
    Same problem as the rest. Motor runs but the door doesn't open. Had to pull the red cord an operate manually. What a pain in the...
  • Anonymous Mar 16, 2009
    wow - they must have a limited life span - I have the same exact problem - as LCM77 asked - Replace gear and sprocket kit - can I fix this myself?
  • smitty234 Mar 16, 2009
    Wow I have the same exact problem - must be a short life span for Sears openers..as LM77 asked - Replace gear and sprocket kit - is this soemthign I can do myself?
  • Anonymous Mar 27, 2009
    motor runs but door does not lift
  • 118 Answers
You have a stripped gear on your opener. Replace gear and sprocket kit
Posted on Feb 08, 2009
I had the same problem. Sear sells a small gear kit with just the plastic gear ($27) or a full gear and bearing kit ($37). I bought the full kit because it has the plastic gear already on the down shaft and made it easy. It took me about 10 minutes to change it but about 30 minutes to get the up/down adjustment back. KEY: close the garage and hook up the chain in the dwon position so you have room to adjust the tention!
Posted on Feb 14, 2010
    Problem Solver:
  • 6 Answers
Reconnect your safty release red cord
Posted on Feb 17, 2009
I have a Craftsman garage door opener, model# 13953674srt1. It will not open or close the door. The motor sounds normal & runs the entire cycle but the chain is not moving. What is the problem?
Remove the cover from the motor unit and you will find the drive gear is stripped. The part number is 41A2817 and is available at any good door service company.
Jan 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage opener went up and the stopped mid way.. motor is humming but nothing moving.. sears 1/2 horse model 2000. Thanks John
Tries unplug,replug it back like about an hour latter.The unit now should be resetting itself,should work again.Still have same problems later,the motor should be check out and fix.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: garage door opener only runs for a foot or two and...
Check to make sure you don't have a broken door spring and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open on my craftsman 1/2 h.p. Garage door opener
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is most likely stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open on my craftsman 1/2 h.p. garage door opener
Remove the cover from the motor unit and you will find the drive gear has stripped. The part number is 41A2817 and is available at any good opener service company. It comes with instructions.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage door opener does not open or close
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER
Remove the cover and I am sure you will find the gear is stripped. The part number for the gear is 41A2817 and is available at Sears or any garage door service company. It comes with instructions.
Apr 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
7,921 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
