Question about Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner
No sound from usb tv stick
I have taken a usb tv stick the video is very clear but i get no sound.tried everything but no result
  • 30 Answers
Hi my tv is just blue with no picture no sound with two symbols in the centre one looks like one half of an hour glass the other a square with a square in it ...I've tried turning off the power and back...
Your firmware is corrupt, to you need to go to the support site for your tv and download the firmware and put it on a USB stick and reinstall ...usually they give you instructions on how to do so.
Dec 05, 2017 | Televison & Video
Video capture ezcap ver36.1s
I had the same problem. I attempted to solve it by using two EZYcaps with the idea of splitting the sound and video streams but as they use the same driver that didn't work. Splitting the video and sound inputs to two USB ports is the key to success. What did work was when I tried plugging in an old USB SoundBlaster sound stick. It is a little thing like a thumb drive but with two mini jacks, one for mic and one for earphones. I plug the mic into the SoundBlaster and the S-Video into the EzyCap. As the SoundBlaster uses a different driver they don't clash.
I also use "SplitCam" to put it all back together and stream the whole lot to the internet. Split Cam also lets me stream to inSpeak video chat while I also stream to Livestream. check out the results on www bgemc.org site. The second EzyCap sits as a spare in my bag. I also audio record the service at the same time. This is all done through a Toshiba Satellite laptop. CPU usage is usually below 30% often down to 10%. By the way I used to use ManyCAM and U-Stream but didn't get good results. All the best. Malachi.
Mar 28, 2014 | bessac.ca Ezcap USB 2.0 Video TV DVD VHS...
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
My RCA L46FHD37 with a Usb port won't play the
The RCA L46FHD37 can only play MP3 audio files and display JPEG image files from a USB drive. See page 41 of the manual to see the details on using a USB flash drive with this TV. I found the manual here: http://www.hdtvsolutions.com/pdf/L46FHD37_0.pdf .
You will need to connect some type of computer with a video player to watch videos. Media streaming boxes, the Stick Computers (like the Intel Compute stick), some tablets/phones and most laptops would be able to connect to the L46FHD37 and display your video files. Some DVD and Blue-ray players will also be able to display these videos, depending on the format and codecs.
I wish that I had better news for you.
Jan 01, 2018 | RCA L46FHD37 46 in. LCD HDTV
Video does not come on TV, sound works but no
you tried a couple of cables and tried two different tv's, with the same results, the outputs to the xbox 360 is on the main board itself so the main board is bad. You did everything I would have done.
Aug 03, 2009 | Microsoft Xbox 360 Console
Sound problem
If you can't see separate audio capture device in VLC and you aren't using separate cable from your device to your soundcard, then you can't get sound with VLC. If you use separate cable, make sure you have selected you soundcard as audio capture device.
Oct 07, 2008 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Access violation in main center exe.
Try un-installing then re-installing the software for the usb stick.
Aug 07, 2007 | KWorld PVR-TV 305U (KW-PVR-TV305U) Video...
Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner Logo
1,306 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
