Every thing works but the heat just doesnt work on both sides. It just blows out cold air. But the day b4 that my car over heated the next day there was no heat.Can some one help me plese?
SOURCE: After car heats up (slow to heat) it stil blows cold until moving
http://www.fixya.com/cars/t1386554-91_ford If this doesn't help you tell me more, if it does, please vote me fixya, otherwise please do not give me any rating at all, the only compensation I get is my Fixya score, Merry Christmas.
SOURCE: heat works on driver side, passenger side blows cold air.
Did you check your coolant level or was it low and you added to it at some point? If so the system my need to be bleed or worst case the thermostat is going bad.
SOURCE: Heat on, blows cold air on passenger side
u will need to repair the passenger side air temp control blend door, either the door is stuck or the small electric actuator that moves it is defective.
SOURCE: No front heat
Are you sure the temperature door is moving ? I have seen the door break or the actuator not move. It is either the door or the actuator.
Blend door for passenger side or blend door motor has failed. Very big job to remove dash and work on it. Except the door motor is accessable from the glove box.
Rudy
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
