Question about NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Plugging the card into pcmcia slot causes a bluescreen. After that a bluescreen on any attempt. Do you have a Vista driver?
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Posted on Nov 03, 2009
Usb pcmcia cardbus card will not lock in place
Are you sure? Push it. On some laptops there might be two slots for the card (one above the other). If your system has space for 2 cards, try the other slot.
May 04, 2012 | Computers & Internet
Acer Aspire 5100-3357 lost function of keyboard, touchpad and USB
hello, this has been one of the most reported problem with the 5100 model. i have 2 of them, and they have done the same thing! one i had 2 find and install a new mainboard-400 bucks! not very cost friendly. i did post a solution more than a year ago, but it is a work around that let me use the acer with the dead keyboard,touchpad,usb- you must buy a pcmcia usb card, it goes in the slot on the left side of the acer 5100. then a usb mouse and keyboard will work. (you can get this cardbus adapter cheap, as 400 bucks is 2 much. these pcmcia cardbus card come with 2 or 4 ports. this will let you use the pc, it has been a great solution for me and a lot of others, been in use over a year like this. acer is no help, unless you wish 2 spend a large amount of $. the one with the new board lasted about 8 months before the usb port stopped working for the second time, i then got a second cardbus usb card and have usb again. sorry for your problem.. good luck! do as i say and the acer will work again.( a problem model) just search for pcmcia usb cardbus you will find many 2 choose from- i picked the ones with the NEC chipset, as these are reliable! be well!
Sep 21, 2009 | Acer Aspire 5100-3357 Notebook
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
NEC USB 2.0 CARDBUS CARD
Your problem is a power overload on the USB 2.0 card. If you plug in a 5volt power supply to the USB 2.0 PCM/CIA card, it will solve your problem. You can also use any USB port on your computer to plug in an A-A USB cable to power the PCM/CIA card and it should resolve the lockup. Also, check and make sure you have enough RAM memory in your comptuer for Windows XP. Recommend 512, but runs much better on 1024 (1 gig) of RAM.
HTH
May 10, 2008 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Usb ports for laptop
Depending on if it has type I or type II PCMCIA slots, you can get a PCMCIA cardbus USB adapter.
They are relatively cheap on Ebay - about 7 bucks.
Just make sure you get one that is the correct card type, and comes with Win98 drivers.
Apr 07, 2008 | Compaq Presario X1000 Notebook
Compaq evo n610c
You need a PCMCIA Wireless adaptor, (this model you are getting has two slots that it will fit in) - and you must make sure you have a wireless router in your house to broadcast a wireless signal for it to recieve.
Mar 28, 2008 | Compaq Evo N610C Notebook
Network card
Any type of PCMCIA network card should work okay.
Go down to Staples, Best Buy or Office Depot and find
a decent PCMCIA network card.  You should be able to find
one for under $50
Mike
Oct 29, 2007 | Compaq Armada E500 Notebook
Windows doesn't detect the adapter
may there is realy a defect on that card. just try use another card and see the result.
Aug 13, 2007 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Techgear 3-port 1394 FireWire CardBus
Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter Logo
464 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
