Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Boss belt keeps breaking
I keep replacing the belt and it last about 2 weeks and breaks
  • Anonymous Feb 26, 2009
    I second that!
  • Emlin May 09, 2009
    Yes. The belt on the Eureka Boss Smartvac Upright 4870 breaks repeatedly. Mine was under warranty, and it was only a few months old, so I exchanged it for a new one (same brand and model). It does the same thing. And it's hard to change the belt.
    I'm going to call Eureka and see what I can do about it. Check back.
galati2k
  • 281 Answers
SOURCE: the belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Posted on May 04, 2009
SOURCE: My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Posted on Jul 10, 2009
Sparchitech
  • 5 Answers
SOURCE: I have a eureka power paw that keeps breaking
Make sure the roller and turbine bushings are clear of obstructions (hair, etc) and spin without excess resistance. As for a lack of barrier or belt guide, make sure that the bushing blocks on either end of the roller (and turbine, but most importantly the roller) are installed identical to each other (otherwise the roller may be in on an angle causing the belt to mis-track). Possibly a part may be missing or improperly installed, but not likely. What's important to remember is Eureka (Electrolux Homecare Products) designed the Power Paw as a cheap, quick source of income to add onto their uprights to cash into the ever-lucrative market of pet owners dealing with pet hair. Like their upright vacuums, Eureka/lux know extremely well the importance of designing their product with a very FINITE life-expectancy, and hence expecting this product to be anything of a long-term or durable solution is evidence only of you having been mislead by marketing. Of all the turbine-driven tools in use today, this one is the most inexpensive, disposable I've had the pleasure of working with. I got one free when they hit the scene. I took it back to work still in the package after seeing its track record evolve.
Long-term solution if you love these turbine-type tools? (and you should, they're great and solve major issues. I own several different ones and am very attached to them as attachments!). Go to a vacuum store and find a robust, long-life version of what these little things are trying to be. They're in a higher dollar-range, but so's a Power Paw if you start replacing it every few months. Ask for one made by Wessel-Werk. German engineering, been around for decades. The made-in-china knock-offs are better than the power paw, but if you're up for it, the actual tool made by Wessel is the benchmark by miles. The only thing possibly comparable in long-term quality and durability is called a RugRat by guys in our industry, and sold by Vacuflo and Kirby and such for decades and decades now. Most vacuum vendors should be able to hook you up. :)
Posted on Jul 12, 2009
  • 21 Answers
How long hace you had your vacuum? THe belts on this vacuum are actually supposed to last a really long time. If the belts brake faster when your using the hose that impies your clutch which tightens and loosens your belt to keep the brush from spinning while the vacuum is upright couild be malfuntioning. If you post your serial number i can tell you if your still under manufacturers warranty.
Posted on Jul 23, 2009
My belt keeps breaking too, but worse is that I can't find out the size for replacing. Who knows the size I need for the Eureka Power Paw?
Posted on Aug 07, 2010
Eureka R4870P belt keeps breaking
There is likely something restricting it from turning freely. Check the endcaps to see if may have dust and hair wrapped around them
Aug 02, 2014 | Eureka Boss SMART VAC Upright Vacuum,...
Belts keep breaking
Check to make sure the brush runs freely before you try to replace the belt. The front brush bearings often become clogged with hair or strands of cotton and once this happens it becomes difficult to get it to rotate and then the belt will fail. Once you've removed it, unscrew the end caps and clear out all debris and then inject a small volume of oil or silicone spray and reassemble. This should fix the problem!
Jun 09, 2012 | Eureka Vacuums
How to replace belt on vacuum cleaner
This URL will take you to a site and show you the Eureka 7600 series of vacuums and the owner's manual that shows how to replace the belt:
http://dl.owneriq.net/c/c5c42eca-6856-41a6-9c0c-1dbd5c429b06.pdf
As long as you are taking the beater brush off to change the belt, please take the time to clean the beater brush and lubricate the space between the brush and the holders found on each end with some WD40. Frozen beater brushes are often the cause of belts breaking.
Please let me know if there are any problems with this.
Paul
Sep 20, 2010 | Eureka Boss 7601 Bagged Upright Vacuum
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Why does the belt keep breaking as soon as I turn on the vacuum?
Hi Have you got the correct belt? If its breaking then the brush end caps or something is clogged. If you can get into the floor head ensure you look at the actual brush roll to see if there is anything is clogged or trapped. Remove all matter of dust and see if that works.
Mar 23, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
1,697 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
