Question about RTO Hope Tech X2 Mtb Mountain Bike Disc Brake Brakeset
Rear Disc brake is rubbingke
I have just purchased a new bike with front & rear disc brakes. The pad on the rear brake touches the disk . I have tried tightening/loosening bits but it doesnt make a differance. Im not intirely sure how to adjust them & its not covered in the hand book either. Please advise.
Trish
  • Anonymous Mar 16, 2014
    front wheel doesnt turrn free disc brake draging
    Problem Solver:
  • 9 Answers
I had the same problem with my Hope mono-mini.
I took it into a shop and the guy showed my ruffly what to do.
On the side that the disk is rubbing you need to put a spacer on the bolt between the brake mount and the bike's mount.
If done correctly (or understood what i meant) it will pull the pad away from the disk a little bit and it will stop rubbing.
Hope it helps
Ed
Posted on Feb 01, 2009
Replacing front brake pads 2001FXST
Front Brake Caliper: All But FLSTS/FXSTS
Remove the front master cylinder reservoir cap to be able to check the fluid level as the caliper pistons are pushed back into the caliper because the fluid level may rise more than the 1/8 in. (3.2 mm) from the top level and you may have to remove some excess fluid if it does so. THEN loosen but do not remove both pad pins with a 12 point one quarter inch socket. THEN remove both metric caliper mounting bolts and remove the caliper from the front forks and brake disc and pry the pads back to force all four caliper pistons into their bores. THEN once the pistons have been retracted, remove the pad pins and the brake pads.
Although the front and rear brake calipers except FXSTD models, use the same exact brake pad set the FXSTD does not and the FXSTD rear pads have a vertical slot cut into the pads. Be sure NOT to substitute front and/or rear brake pads for the other on these bikes. On the right side of the vehicle the pad with the two tabs installs on the inboard side of the caliper and on the left side of the vehicle, the pad with the two tabs installs on the outboard side of the caliper.
THEN install new pads into the caliper noting that the curved portion of the pad faces to the rear of the bike, and loosely install the pad pins until you hear an audible click from them. THEN re-attach the caliper to front fork, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long caliper mounting bolt into the top hole on the fork leg, install the short mounting bolt into the bottom hole on the fork le, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm) and final tighten the top mounting bolt also to 28-38 ft-lbs (38.51.5 Nm) and final tighten the two pad pins to 180-200 in-lbs (20.3-22.6 Nm).
THEN and whenever new pads are installed, before moving the bike pump the brakes until brake fluid pushes the caliper pistons and the pads out and verify that the pads are against the brake disc and then rotate the wheel to ensure there is not any excessive drag between the pads and the disc, check for proper fluid level in the reservoir and if necessary top it up with DOT 5 Silicone base brake fluid only, install the reservoir cover and tighten its screws to 6-8 in-lbs (0.7-0.9 Nm).
THEN and whenever any work has been done on brakes always test the brakes at low speed before operating on a roadway or at higher speeds. THEN test brake system light and if during the road test the brakes feel spongy at all bleed the system and after obtaining a hard lever or pedal road test the bike again.
Oct 04, 2014 | Cars & Trucks
How to check goldwing1500 front brakes?
start here ... http://hrca.honda.com/ ... sign up and get immediate access to generic service manuals. You can also purchase model specific manuals for a reasonable price.
As you know, the front and rear brakes are independent of each other ... engaging the front has no impact on the rear and vice versa. Is your disc drilled? When I apply the front brakes on my bike, I can hear the noise generated as the pads pass over the holes in the disc ... could that be what you are hearing?
Jul 21, 2013 | 1999 Honda GL 1500 SE Gold Wing
2003 Suzuki VL 1500 Intruder LC REAR DISC RATTLE,HOW DO I REPLACE IT?
Hello Dale, this is an easy job on your bike. Use a flat head screw driver and remove the brake pad cover...it will pop off.
Remove the hairpin type clips off of the ends of the brake pad pins.... Use pliers & pull the brake pad pins out from the front of the rear brake caliper....Clean the rear brake caliper's piston with brake cleaner. Use a rag and wipe it clean...Reinsert the old brake pads into the caliper. Place a pry bar between the brake pads, then push the inner piston into the caliper body, this will allow room to install new pads.... Remove the old brake pads...Coat the brake pad pins and the new brake pads metal back plates with high-temperature grease.
Slip the new brake pads into the rear brake caliper, then push the brake pad pins halfway into the caliper. Slip the spring clips into place between the brake pads and the brake pad pins. Push the brake pad pins completely through the rear brake caliper. Push the hairpin clips back into the brake pad pin tips. Snap the brake pad cover onto the top of the rear brake caliper....
Pump the rear brake pedal until the pedal feels firm, indicating that the brake pads have closed around the brake rotor...No bleeding will be needed because the system was never opened - That's all there is to it...i hope this information is helpful & good luck with your bike.
Nov 22, 2011 | 2003 Suzuki VL 1500 Intruder LC
My 2007 nissan quest 3.5S mini van is in almost perfect condition until I recently discovered something deviating from what I know is common to brakes. I do all maintenance work to my cars (nissan VW,...
Master cylinder and/or brake booster could be the problem. A tiny bit of air in the system will effect your braking abilty. A fault in the ABS system would prompt the computer to trigger the ABS light. If you have brake shoes on the rear, make sure they are properly adjusted. Hope this helps.
Jul 04, 2011 | 2007 Nissan Quest 3.5 Minivan
I have a 2003 toyota corolla S edition. I need to get the rear brakes replaced, but when I went to the parts store for rotors and pads, they told me I might need drums and shoes. How can I find out what...
The best way would be to remove the wheel and see if you have drums or discs. Disc brakes on the rear will look like the front brakes, as discs are required on the front of 1970 vehicles and newer. You will see the rotor which will be shiny where the pads have rubbed it. On a drum, it will look like a rusty metal bowl facing away from you. If you have custom wheels you may be able to see through the spokes, but dust guards will not let you tell from the back.
Mar 03, 2011 | 2003 Toyota Corolla
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Jan 25, 2011 | 2007 Toyota Camry
What tools needed to replace front brake pads & rotors
Brake Pads
Front
3.4L front disc brake assembly
4.0L and 4.7L front disc brake assembly
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Clip, 2 caliper pins, the anti-rattle spring then remove the 2 brake pads
      and the 4 anti-squeal shims
To Install:
CAUTION
Only replace brake pads on 1 side of the
vehicle at a time. Failure to use this procedure could cause the caliper pistons
on the opposite side of the vehicle to pop out requiring the reconditioning or
replacement of the brake caliper.
  1. Remove a small amount of brake fluid from the master cylinder.
  2. Install a used brake pad into the caliper and compress the caliper pistons.
  3. Apply disc brake grease to both sides of the inner anti-squeal shims.
  4. Install or connect the following:
    • Anti-squeal shims to the new brake pads
    • 2 brake pads
    • Anti-rattle spring and the 2 caliper pins
    • Clip
    • Front wheel
  5. Depress the brake pedal several times to seat the brake pads.
  6. Check the brake fluid level and top off as needed.
Rear
To Remove:
    this section.
    • Rear wheel
    • 2 cylinder slide pins from rear caliper assembly
    • Caliper assembly from rear caliper mounting
    • 2 brake pads with anti-squeal shims from rear caliper mounting
    • 2 anti-squeal shims from each disc brake pads
    • Pad wear indicator plate from the inner side disc brake pad
    • 4 pad support plates from the rear caliper mounting
To Install:
  1. Install or connect the following:
    • 4 pad support plates on the rear caliper mounting
    • Pad wear indicator plate on the inside brake pad
      Note: Install the pad wear indicator facing downward.
    • Anti-squeal shims on each brake pad
    • 2 disc brake pads with anti-squeal shims to the caliper assembly
  2. Apply lithium soap base glycol grease to the sliding part of 2 caliper slide
    pins.
  3. Install or connect the following:
    • Disc brake caliper assembly with 2 caliper slide pins
    • Torque to 65 ft-lbs (88 Nm)
    • Rear wheel
  4. Depress the brake pedal several times to seat the brake pads.
  5. Check the brake fluid level and top off as needed.
--- Removal & Installation
Front
To Remove:
    this section.
    • Front wheel
    • Front brake caliper assembly
  3. Make matchmarks on the disc and the axle hub.
  4. Remove the front disc.
To Install:
  1. Align matchmarks and disc onto axle hub.
  2. Install or connect the following:
    • Front brake caliper assembly with the 2 bolts
      1. Torque to 90 ft-lbs (123 Nm)
    • Front wheel
Sep 23, 2010 | 2003 Toyota 4Runner
Replace rear brake pads
Rear disc brake pads offer better performance and are not as affected by moisture like conventional brake shoe style brakes are. Rear disc brakes are similar to front disc brakes. The main difference is that rear disc brake systems must incorporate the emergency brake system. There are two methods widely used for the emergency brake with rear disc systems. The first system is a brake shoe inside the brake disc that is actuated by the emergency brake lever. The second is a screw style actuator inside the brake caliper. When activated the brake pads are forced into the brake disc and held tightly by the emergency brake lever.
READ COMPLETELY BEFORE STARTING
Step 1 - Identify Rear Disc Brake Components
rear_brake_pads.jpg Rear disc brake assembly includes; rear brake disc, rear brake pads, brake caliper mount and a caliper mounting screw. (Note: Some vehicles do not have the rotor mounting screw.)
Step 2 - Removing the Rear Brake Caliper Mount Bolts
rear_brake_pads_2.jpg To replace rear brake pads and rotors the rear brake caliper needs to be removed. First loosen the rear brake caliper mount bolts and remove them. Turn counter clockwise.
Step 3 - Lift Rear Brake Caliper from The Caliper Mount
rear_brake_pads_3.jpg After the caliper mount bolts have been removed, gently lift the brake caliper from the caliper mount. Inspect the caliper slides; they should move freely in the caliper mount. Remove rear brake pads and hardware.
Step 4 - Removing Caliper Mount Bolts
rear_brake_pads_4.jpg With a socket wrench or other appropriate removal tool, loosen the rear brake caliper mounting bolts. Remove bolts and lift the caliper mount and remove it from the vehicle. Remove the retaining screw from the disc mounting hole. Tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub holding on tightly, using both hands. You do not want to drop the rotor.
Step 5 - Removing Rear Brake Rotor
rear_brake_rotor.jpg Remove the retaining screw from the disc mounting hole, tap the rotor gently to release any rust that has accumulated between the rotor and bearing hub. Lift brake rotor from wheel hub, hold on using both hands and do not drop.
Step 6 - Install New Brake Rotor
rear_brake_rotor_2.jpg Check the new rotor against the old brake rotor to make sure they are the same size. Clean the mating surface on the wheel hub before the new brake rotor is installed. Reinstall rotor retainer screw.
Step 7 - Reset Rear Brake Caliper
rear_brakes_7.jpg Before new brake pads can be installed, the rear brake caliper must be reset. The reset tool winds the piston back into position so the new brake pads will fit. This style of brake caliper will not compress with a clamp tool; it can only be reset with the proper reset tool.
Step 8 - Reinstall Rear Caliper Mount and Install New Rear Brake Pads
rear_brake_rotor_3.jpg After the caliper has been reset, reinstall caliper mounting bolts and make sure the bolts are tight. Then match up the old brake pads to the new brake pads. They should be exactly the same except, of course; the old ones will be worn out. Check the new brake pads for proper fit and install any brake hardware that is required.
Step 9 - Remount Rear Brake Caliper
rear_brake_rotor_4.jpg Reinstall the brake caliper, align brake pad hardware and reinstall caliper mounting bolts. (Note: align the rear peg of the brake pad to the groove in the caliper piston.) Recheck and retighten all caliper and caliper mount bolts. Bleed brake system to relieve any air in the system. Before driving the vehicle, push the brake pedal down and let it up slowly. This operation forces the brake pads to travel to the brake rotors. DO NOT DRIVE VEHICLE until proper brake pedal operation resumes. When test driving vehicle listen for any unusual noises during the operation of the brakes.
WARNING! Always have the vehicle under inspection on level ground, in park with the emergency brake on. Always wear protective eyewear, gloves and necessary clothing before inspection or work begins. Never crank an engine over when anyone is near the battery or engine. Always have an operational fire extinguisher close by, obey all first aid instructions in the event of an injury. Never stand in front or behind a vehicle when cranked over or running. When engine is cranked over keep hands and clothing away from rotating components. Never move a car without proper brake pedal operation.
Jun 01, 2010 | 1995 Saab 900
Avid juicy ultimate, rear disc brake vibration and noise
It is a lose bolt somewhere, OR somebody has touched your rotor with their hands OR there is oil in the pads.
Check ALL your bolts for correct torque, buy new pads and Rubbing Alcohol and install them AFTER you clean off the rotor and your hands with the Rubbing Alcohol. TRY not to touch the rotor or the pads with your hands.
Dec 30, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
2001 Focus zx3 rear brakes- pads or drums???
If they look like a smaller version of your front brakes where you can see the disc (should be shiny on the side of the disc where the pad touches the rotor) then you have disk brakes.
If it's all black, or all kinda of rusted looking and all you see is a "cap" over everything behind the rim, then it'll be a drum...
95% of the zx3's have drums
only 5% of zx3's had discs. The ones that have disc brakes, also came with traction control as part of the package.
Sep 18, 2009 | 2001 Ford Focus
RTO Hope Tech X2 Mtb Mountain Bike Disc Brake Brakeset Logo
418 people viewed this question
Top RTO Cycling Experts
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
