Question about JVC HD-52G786 52" Rear Projection HDTV
HOW CAN WE PROGRAM OUR TV WITH OUT A REMOTE
MY TV IS TELLING ME THAT I HAVE A WEAK SIGNAL I CAN'T GET A PICTURE DO I HAVE TO HAVE DIGITAL CABLE? BECAUSE I ONLY HAVE BASIC CABLE.
I think you have the tv on digital mode. You need to use you remote to exit out of that mode by pressing the D/A button.
Posted on Feb 07, 2009
    Genius:
  • 2,920 Answers
Even your basic cable should come in.it sounds like you have a weak tuner
Posted on Feb 01, 2009
Why am I being told that my signal to my tv is weak and that must come to you for assistance.
Are you on cable or Arial If on Arial you may have to turn the head one way or the other to get the program to come in also weather conditions have a lot to do with this.Weather effects the cable reception as well. If the TV works most of the time but not other times it could be the weather. or a weak booster on your areal
Sep 22, 2014 | T-View Car Audio & Video
Tv comes on cannot get a picture nor sound. followed instructions in manual regarding source , enter , picture, enter , channel, enter.etc., I can get to the menus but nothing else. It is not on cable...
If you have an antenna, you are trying to receive off-the-air broadcasting. Remember that a couple of years ago the US switched to digital broadcasting and analog stations went off the air. Your TV does not have a digital tuner, so you need an digital-to-analog adapter if you want to receive anything.
The US government had a program before the switch to help pay for the adapters, but that's long past now. Radio Shack sells them as do other retailers, and you can find them online as well.
The adapter picks up the digital broadcasts and converts them to a channel 3 or 4 TV signal that the analog tuner in your TV can receive. Some models of converter also feature video and audio jacks so you can connect it as an AV source like a DVD player. Once you've hooked the antenna to the converter and the converter to the TV, you'll be able to watch your local channels again. Maybe, that is.
The trouble with digital broadcasting is that signal strength makes a huge difference in reception. With analog, a weak signal would still give you a fuzzy but watchable picture. A weak digital signal may not even be detected, or you might get a picture that breaks up (pixelation) or freezes on the screen. You don't say what kind of antenna you have, but unless you're in or very close to a large city or near the station's transmitter, simple rabbit-ears may not be enough. Many people found after getting an adapter that they needed a better antenna, even something on the roof. In some areas (valleys, remote areas, places surrounded by many tall buildings, for instance) people found they could never get any channels. If you do in fact have a digital converter already (you didn't mention one), this could be the reason you can't get anything.
Hope this helps you figure out what's wrong. Thanks for using Fixya!
Dec 04, 2010 | Craig CTV-41331 13" TV
Digital TV problems
You are suffering from a poor signal. Digital TVs will display 'blocking' (partial freezing of the picture in square or rectangular blocks) or total freezing of the picture, when the signal is too weak.
You don't say if this is a recent problem on a set that has been working correctly - that info. would be helpful. However, things to check include:
Has the aerial moved (wind?)
Are you using a new extension coax cable? If so try another one, as connections may be faulty.
If this a new TV, and you have not used digital previously, your aerial may not be high enough gain for a digital signal, but that is unlikely unless it's a nery old aerial.
Feb 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
I hit a key on the remote and now the TV says, "No Program or Weak Signal." How do I go back to the picture?
If you are using the original TV remote it sounds as if you have pressed the input button on accident... try pressing the input button one at a time until your picture returns....
Good Luck....
Jan 12, 2010 | JVC AV-32D305 32" TV
Our tv looses it sound as the picture breaks up...many a time it say weak signal
check your signal source, make sure all connections are good. Check that the signal is good at that location with another TV if possible. Check your cable connections, or antana, if using a digital converter box, check those connection as well. if running rabbit years, try to get it as high off the ground as possible. I you have cable or satalite, call your provider for assistance as it is a weak signal.
Nov 08, 2009 | Philips Magnavox 20MT133S 20" TV
The picture seems very coarse and has diamonds running across it
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
No signal or weak signal
Sorry I see the model,
hold the Menu button on the TV (not on the remote) down for three seconds.
Note: Shop Mode is activated in the same manner: Pressing and holding the Menu button on your TV for three seconds. To avoid accidentally setting your TV to Shop Mode, avoid pressing and holding the Menu button on the TV for three seconds or more.
Sep 21, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
148 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
