Question about Hoover S3755 WindTunnel Bagless Canister Vacuum
Need an on/off switch for a Hoover Windtunnel Canister S3639
I have removed and cleaned switch twice. It now works, but need to get one for next failure. Do you have a source?
  • majora Feb 01, 2009
    Site defaulted to wrong model Hoover I have a Hoover WindTunnel canister Model S3639.
MY WINDOW EXPLORER IS NOT OPEN
Posted on Feb 01, 2009
Repair manual for Hoover Vacuum
If you would like a repair manual, we can special order one for you for your Hoover S3639. Call us at AAAA TEVA Monday through Saturday from 9am to 6pm MST. Our number here is 303-770-6321.
Jul 18, 2012 | Hoover S3639 WindTunnel Bagged Canister...
Hoover S3639 Suction Failure/Turns itself off and restarts later
If you did all this already the motor is not having power, must be replaced.
Sep 06, 2008 | Hoover S3639 WindTunnel Bagged Canister...
The bottom of the hoover wont work. its not picking anything up and not spinning round.
You most likely will need to replace the belt on this model. There are 4 screws in the corners of the bottom power nozzle. DO NOT remove the 3 that are grouped together (these are the motor screws). once the top is removed then remove 3 roller cover screws. replce belt and reassemble in reverse order.
Oct 28, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hoover U6434-900 WindTunnel Bagged Supreme
R U SURE THAT IT IS NOT JUST A SAFETY CUT OUT SWITCH , SOME MODELS HAVE A BLACK BUTTON BEHIND THE BRUSH HEAD DIFFICULT TO SEE SOMETIMES
Aug 17, 2008 | Hoover S3639 WindTunnel Bagged Canister...
How do you open hoover s3639???????
Take out all the tools out of the tools compartment. The screws are "hiding" under the tools.
Jul 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Hoover S3755 WindTunnel Bagless Canister Vacuum Logo
130 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
