I can't download anything, and the BIOS dignostic said the hard drive is missing. I have no recovery disk either.
Hello I was plagued by this same message for weeks and it would randomly come and go. I asked many people for help all said things like failed hard drive, failed motherboard, to windows 8 update malfunction, corrupt registry and so on. Then one day it hit me, In a fit of frustration I took apart my entire computer and carefully inspected for any damage at all and the one place I found a little bit of wear and tear was on a $2 red wire that connected the sata 1 port on the motherboard to the sata port on the hard drive. It made perfect sense the reason the computer randomly cant see your Operating System is this wire is wearing down and can come lose for many reasons. So this potentially hundred dollar problem was fixed by a $2 wire.
SOURCE: ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
SOURCE: A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
SOURCE: i have Dell inspiron 1525
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
Testimonial: "thanks for your reply its very helpful"
Follow these steps to fix Disk Read Error::
1. Run CHKDSK /R /P from the recovery console (it will typically find no error)
2. run FIXBOOT from recovery console (typically has no result)
3. run FIXMBR from recovery console (typically has no result)
4. Run the manufacturer's diagnostic utility, downloaded from their website (it will typically find no error)
5. Changing the drives from cable select to Master/Slave may fix it.
6. Replacing the data cable may fix it, but usually not.
7. Setting the BIOS to use defaults may fix it, but usually not.
8. Changing the BIOS drive settings from auto to user-specified, ensuring that LBA is selected may fix it.
9. Pulling the CMOS battery to let the BIOS lose it settings may work.
Some helpful tips::
