Electronic Arts FIFA Soccer 2002 for Windows Logo
A
Anonymous Posted on Feb 01, 2013
Fifa 2002 doesn't work in windows 7 - Electronic Arts FIFA Soccer 2002 for Windows
Passenger window doesn't work on 2002 yaris
just needs a new window motor :-) they are not that expensive
20helpful
2answers
Why Fifa Manager 13 does not work with Windows 8
Hello, i had the same problem. GO right click on the exe, then in properties chose compabilyty and then Windows 7. That worked for me :)
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
2answers
WAnt to know if fifa 11 can be played on his machien lenovo c200
By the looks of the information you gave me...it seems that FIFA '11 might not be able to or may have a real hard time playing on your machine, but it doesn't hurt to try! If it doesn't work, then just simply uninstall it.
Hope this helps ^_^
Cabal online ph doesn't work on my windows 7 why?
yup ..cabal doesn't work in window 7 os .only window xp operating system can installed it :) try to change your OS then play cabal
I have a TM-T88IIIP model MI29C and windows 7 operating system. Do you have a download available for this?? Thank you Carol
Here's the driver link for the Epson TM-T88IIP Receipt Printer: http://www.posmicro.com/RECPRINTERS/EPSON/Epson-TM-T88II.htm
This link will take you to the download page for the manual as well. This driver is supposed to be for Windows XP but should work for Windows 7 32 bit OS. Give it a try - if it doesn't work or won't install, then post back to this solution and I will help you further. It is likely that a Windows 7 driver doesn't exist, but unless you have the 64 bit version of Windows 7 this driver should work one way or another.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Sir, I am having trouble with E0001 when i click on play in the fifa 2011 open window.Please help me.
This error means that you PC doesn't support Fifa 11. You will have to upgrade your computer to get this game to work.
3answers
I cann't play fifa 11
you need a graphic card - I have geforce 9600
7helpful
2answers
E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
4helpful
Hi .. I'm trying to play fifa 2000 on windows 7 .. I'v done many configuration to run it .. and it runs .. but when I load a game .. I mean a match .. Fifa crash and return to windows .. how can I fix that...
I am also facing the same problem on my windows 7 pc...whenever i open the game fifa 2000 its open normaly ,selecting the match and team , then go to play the match it get stuck "tell that windows explorer has problem running fifa 2000.so close the program automaticaly.:) :). I need a solution please anybody tell me how can i fix this ..:)
thanks
Top Electronic Arts Video Game Consoles & Games Experts
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
