Question about Toshiba Satellite A25-S207 Notebook
Thanks for the advice on the A25 memory upgrade, greta link!!!
Where is the memory located in a toshiba a25 laptop
The access the memory cards you need to do a little dissembly. Remove the battery then remove the securing strip and the keyboard you will find the memory below the keyboard.
Mar 20, 2010 | Toshiba Satellite A25-S207 Notebook
I need a manual of A25-S3072 let me know where I can find it. thanks, Joe
You may try the link below:
http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Jan 23, 2010 | Toshiba Satellite A25-S3072 Notebook
How do you take a Toshiba A25-S307 apart to clean out dust?
I managed to locate a website providing some instruction on the disassembly of Toshiba laptops. While the one aimed at your laptop isn't for the purpose of cleaning out the case, I think it will get you close. I found both articles here:
http://www.irisvista.com/tech/
Article 1 (For the A25) to reach the memory area of your laptop: http://www.irisvista.com/tech/laptops/ToshibaA25/Satellite-A25-memory-upgrade.htm
Article 2 (For the A20) to disassemble the laptop and replace hinges: http://www.irisvista.com/tech/laptops/ToshibaA20/Satellite_A20_replace_hinges_1.htm
As mentioned, the article for the A25 isn't specific to what you're attempting to accomplish. Yet between the two articles, I think you can get the job done. Just remember, ground yourself before working on the laptop. You don't want to destroy anything because you accidentally discharged static electricity.
Let us know how things turn out, or if you require any further assistance.
Jan 05, 2010 | Toshiba Satellite A25-S307 Notebook
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
Memory upgrade
It looks like the A25 will only hold 1g of PC2100, which is really plenty, unless you're a serious gamer or into graphic arts and need an extreme high definition video. Here's a link to the memory configurator that I use in order to find the proper memory, max held, and the chipset. You might double check to be sure I looked up the right machine. If it is the right machine, I suggest two 512mb chips. Sometimes you can't run one 1g chip because the slots are designed to only hold a certain amount, and if they will hold the 1g chip, sometime the machine doesn't run properly. It wants to use both slots accordingly, running only one creates conflicts. This should help in boosting your RAM.
Aug 26, 2008 | Toshiba Satellite A25-S207 Notebook
Low storage memory
Kindly format your handset and go to connections option in settings and select FTP and select storage memory in my documents
And check wether its done or not
SIKANDAR KHAN i m using greta HTC P3400 with no probs till now
Aug 20, 2008 | HTC Touch P3450 Smartphone
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
RAM Memory Inaccesible
What model is it? You take a peek under the Keyboard??
Jun 06, 2008 | Toshiba Satellite A25-S207 Notebook
Upgrade
You can put 512Mb in each slot.
Look here for the details of your notebook.
http://www.fixya.com/support/p264641-toshiba_satellite_a25_s207_pc_notebook/manual-14808
Mar 26, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S207 Notebook Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
