Question about Hitachi CP-X445 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
-I have cleaned the air filter and i go to menu-options-filter time to make the reset but nothing happen. I puss the middle button in the remote control(enter),also tried the reset button but nothing...
-There are also blinking me the lights of LAMP and TEMP up of the projector. What should i do? I just bought the projector second hand.
Please let me now, thanks
Paris
  • Anonymous Apr 12, 2009
    i had the same problem, thanks for tht info leon, worked a treat
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Posted on Apr 27, 2009
Hi Pan, it might help but i posted a few moments ago concerning a CP-RX60 (and CP-RS55), but when you get to the filter timer option, press and hold the right cursor button on the projector to enter the reset menu. also go into the advanced menu to reset the lamp time in the same fashion
Posted on Mar 11, 2009
Warning lamp blinks red. Tried new bulb just for kicks, but not the problem. Any ideas?
Time to clean the air filters. See manual how to clean air filters and reset the filter cleaning counter in the device.
Feb 16, 2011 | Sanyo PLC-XU101 Projector
Reset filter timer
Most projectors use a menu-driven system...enter the menu, look for the lamp reset menu--DON'T RESET THE LAMP! Usually the filter reset option is with or near the lamp reset option. And, most probably, you'll have to use the remote to access the menu options.Hope this helps. Btw, have you cleaned the filter recently?? I clean mine once a week! Projectors generate LOTS of heat...Any extra heat ages the internal components prematurely causing lamps to fail, LCD panels to break down, and circuit boards to display incorrect images. ---Rick
Sep 05, 2009 | Hitachi EDX-3280 LCD Projector
Pop saying check filter
Hi there...FIRST remove the dust filter and clean it with some compressed air, or you can leave it in place and use a vacuum cleaner hose to suction off the dust. Some projectors have a sensor that gets reset when the filter is removed. A lot don't. Check the onscreen menu for a reset option for the dust filter. This option may be only accessible with the remote control...DON'T reset the lamp hours! The most important thing with LCD projectors or any other projector, for that matter, is to keep the dust filters clean--think of someone putting their hand over your nose and mouth. The projectors emit a *huge* amount of heat and need plenty of air flow to remain cool. Also, the benefit of cool air keeps the delicate LCD panels from aging prematurely!---Rick
Jun 26, 2009 | Hitachi Performa CP-RS55 Multimedia...
I have 2 SVGA60 Projectors that are saying Temperature!!! One does it then the other about 10 minutes later
several reasons, it could be you havent had its 1000Hrs service and is overheating or filter needs cleaning or lamp is past its change time and is generating too much heat or sensor can sometimes come away and drop into light path causing false sensing of temp.
Marc Engineer
Dec 17, 2008 | Mitsubishi HC100U Multimedia Projector
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-X445 Multimedia Projector Logo
926 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
