llajajlajjajlook my friend td sensor is located in under tank devolper yo will see it but yo this disput belong to acount of devolper mesure it and check bias and high voltage board
Remove the waste bottle then the drum unit from the front of the machine.**Cover the drum unit so it is not exposed to the light.
Remove the Developing unit and empty the developer from the dev unit into waste bag. Once all the developer is removed...take the new bottle of developer and pour it all into the dev unit. Replace the plastic cover back onto the top of the dev unit. Re-install the dev unit back into the machine, then replace the drum unit back into the machine then replace the waste toner bottle. Close the front door. Enter the copier adjustment mode on the keypad by pressing "user preset,Orig size(Ledger), and Multi-copy key #3 in sequence.
Then press Multi-copy key #8 , then press the Print key.
Now select th code "09" and Press Print.
The machine will run for approx 2 minutes to initialize the new developer. Press Clear/stop and User preset to escape from the service mode. You are done.
hi ther are so many coz for that but u just start with step 1. try to set lavel of your machine. 2. clean the scanner mirors. 3. clean the crona wires both sepration and charge. if it solve your problem ok if not just cheq the devolper unit may be low devolper jut add new devolper and re calebrate .
thanks
its very simple just buy devolper and chip for devolper counter ( just empty the devolper from devolper unit and put new devolper in it and replace the counter chip at the left side of devolper unit )
thanks
Definitely a waste of time and money. Bluetooth is REALLY slow, so you might as well go and buy a wireless card if your computer isn't already equipped with one.
hi
am AJAY FROM INDIA
off the printer and open upside cover,see 'the waste ink absorber if there any spunge pull that
and empty the waste ink from sponge or waste ink absorber
ok
